0 EFI hose clamps
Last Post: smm1200
0 Clutchlite ramps with pictures
0 EFI fuel tank hose fail
Last Post: smm1200
0 Removing oil pump
0 In tank pump and filter work
Last Post: smm1200
4 Oil Filter
0 once a cheater always a cheater?
Last Post: tonyhds
0 Hi From NJ
0 WTF is it with these F'n rocker cover leaks!
Last Post: Kawa110
0 Grounded
0 Hardtail sporty ideas
4 The no-debate OIL POLL
0 What engine oil do you use?
0 Cost of ejikation
Last Post: shooterj2003
0 Cheap Generator Source?
0 Sticky Valve fix
Last Post: Sadsack
0 Ride Report 2019 Black Hills, Grand Teton Mtns., Rocky Mountain Ntl. Park
0 Roland Sands Design Nostalgia Air Cleaner Black Ops
Last Post: darthrinzler
0 Sportster Spoked Wheel Options
Last Post: Desertfox
0 Iron OEM Black Exhaust
0 OEM Satin Black Mirrors
0 Coil Relocation Bracket w/ Satin Black Cloth Cables
buell, cams, jetting, raspberry, xb12
Old 22nd January 2015
fulldelta fulldelta is offline
Sportster/Buell Model: Sportster 883 XLH
fulldelta is a name known to allfulldelta is a name known to allfulldelta is a name known to allfulldelta is a name known to allfulldelta is a name known to allfulldelta is a name known to allfulldelta is a name known to allfulldelta is a name known to allfulldelta is a name known to allfulldelta is a name known to allfulldelta is a name known to all
Talking Questions??? Cams, Ignition, Jetting, Computers on a '98 and more...
I have a 1998 883 XLH. With an aftermarket aircleaner and drag pipes.
Pics: http://xlforum.net/forums/s....php?t=1842680
Recently purchased Buell '07 XB12 complete top end.
Got a front mount bracket from HammerPerf.
I plan to install everything jugs, pistons, heads, rockers, and covers.
Question 1: Will the this clear the frame?
I want to use the Buell PCV Valve system so I don't have to drill breathers in the heads. I have read it is a better solution as oppose to catch cans anyway. So I have spent a lot of time polishing the rocker covers ideally to take them to a mirror finish instead of the ugly oil stained textured finish that they had. From what I have read this has been done but it is difficult (possibly have to unbolt the motor).
Question 2: What cams should I grab?
I am leaning toward Andrews N4's. I am unsure if I should buy these new or try to find takeoffs from a Buell (and switch the 1 and 4 gears). Also I am considering some more agressive stock takeoff than a stock 883 has. Or something else, please drop some knowledge on me pertaining to my set up. N6's? Some other brand that wont cost me $250?
Question 3: What Ignition Module? Is it neccessary?
I am leaning toward a Dynatek 2000i. Mainy for the price. But also I am considering replacing my single mechanical speedometer with a Raspberry Pi and touchscreen. Then I can integrate the stock speedo/tach wiring as well as the engine temp sensor for the buell head. Plus gps and the ability to start the bike from my phone... not that that is neccessary at all. Maybe a battery meter too. The dyna I think is programmable via usb so if I need to I can use the Pi to program the ignition curve while I am doing 80mph.
Question 4: Have I lost my mind?
Many have said yes... I won't hold it against you.
Question 5: Jetting the carb? / New Carb?
Had not planned on buying a new carb. Should I? Currently I believe I have a stock pilot and my main jet is a 190 which is very rich for the 883. But with a 1203... I don't know. I didn't jet it to a 190 the guy before me did, I just have yet to change it.
Question 6: Anything else?
My budget is actually tight I know the computer thing sounds expensive but it's not Pi's are cheap. I have thought maybe upgrade the pistons, but it is my impression that Buell's stock ones ain't bad in the XB12 and plus then I would have to pay to get it honed probably. Head work... I don't know I think cams and ignition may be a better spend. Its probably either or at this point and I don't thinkyou can do head work without the others though.
Whose got the knowledge?
einheit 13's Avatar
einheit 13 einheit 13 is offline
Senior Master Bike Builder
Sportster/Buell Model #2: 883/1200 Hugger
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Bonneville America (904)
einheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to all
Ultima ignition, same as the Dyna at like half the cost. Lat time I bought one is $164 for the complete unit with coil.
Life may begin at 30, but it really interesting around 150!
Awesome, I was wondering this thank you.
rejeanprimeau's Avatar
Craig list has lot of screamin eagle cams. Cheap an proven
From what I have read I think I can run SE .536's as a bolt in because of the top end I am using. I am not 100% sure even maybe SE .551's. Decent amount of options it seems because I am not limited to the .500 bolt in limit that the old sportster heads had.
More people please chime in to any of the questions above. You help me and I will do write ups to help others for the future.
