Last Post: 83XLX
Last Post: Bryan83taco
0 Floating front disc
0 MC lift table modification
Last Post: brixtonanima
Last Post: xraytoken
Last Post: duffy
Last Post: ryan0ryan
Last Post: thecarnie
4 greetings from quarantine!
9 CV carburetor gurus...
Last Post: Dougray
Last Post: 83XLX
0 1970-71 XL Fuel Tank ?
Last Post: 72 Ironhead XLH
14 Installed Vulcan 3 Degree Raked Cups
0 Diagnostic code ?
0 Resto-Repair 84 ironhead
0 Who runs 70wt. oil
Last Post: Kbetts
chopper, kicker, kickstart, shim
Old 27th August 2015
Kickflippin Kickflippin is offline
Sportster/Buell Year: 1976
Other Motorcycle Model: Yamaha XS650
Other Motorcycle Year: 1978
Kickflippin is an unknown quantity at this point
Default '76 kicker issues. Shim needed?
2 issues with my '76 XLCH chopper project. Engine is in the frame together but...
1. The kicking stroke will kick just fine a few times but eventually *POP* on the down kick like the ratchet teeth aren't grabbing. I can't feel any in-and-out play on the kicker shaft, and all the gear teeth are in great shape, but there is not a .007" shim installed. Could I need one or two anyway? Once in a while the kicker stays down too, and i have to bump it back up.
2. I've only got about 2" of clearance on this frame. The pedal just about hits the ground before finishing the stroke, forcing me to ratchet up, step on the pedal, then release again before being able to make another kick. If I adjust the assembly forward inside, the pedal ends up a little too far forward for an efficient kick. Any work arounds known? Thanks. kicker pic below.
8ball's Avatar
8ball 8ball is offline
Bike Builder
Sportster/Buell Year: 1973
Sportster/Buell Model #2: xlch stroker
8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of8ball has much to be proud of
Well first ur kicker petal seems to b on facing the wrong way but I'm sure that's not the answer u needed
Next if the ratchet is slipping check out Dr dicks giving kicker slip the boot in the stickies ur bushing is probably toast but it'd a fairly cheap and easy ish thing to fix if u follow the sticky
Lastly for the kicker hitting the ground mine does it as well tho I have a bit more clearance but it can b a good thing for when the kicker does slip it will prevent over extending ur knee which is very painful several guys on here have ended in surgery from it
"ya...i saw a guy do this once... " -DR DICK
8ball's Avatar
Bike Builder
http://xlforum.net/forums/s....php?t=1172767
It was indeed. Quick mock-up for pics, NOT how I was attempting to kick. I would deserve the broken shin for that one. thanks for the sticky link, My bushings were fairly new, could still be bad though. I'll follow his recommendations.
8ball's Avatar
Bike Builder
I kinda figured it was just for the pic but u nvr kno lol
doodah man's Avatar
kicker arm not returning could be binding on the bushing in the sprocket cover. make sure the bolts are tight. the next time you kick through and it sticks, loosen the cover bolts and see if it frees up immediately - if it does there is some kind of misalignment.
Icefire's Avatar
Icefire Icefire is offline
Icefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura aboutIcefire has a spectacular aura about
Unfortunately a lot of them do this, leading to the dreaded "Sportster knee"...Mine does, so I usually use the button, I'm lucky to have both on my 75 XLH. Kicked it for years, though, and overextended my knee many times...Dr. Dick has the solution on the other thread, though..
Keith Black .010 over pistons, Andrews PB+ cams, Accel Supercoil, solid core wires, rejetted Keihin Butterfly carb, S&S air cleaner, Unleaded conversion, valve job, heads bored, new rocker arms, rockers, pushrods, seals, Accel Cyclelite Platinum plugs, Accel 8.8 mm plug wires, Big Boar BB1000 battery, O-ring chain, upgraded handlebar controls,Maxxis tires, GMA front brake, drilled disk, Mustang seat, custom grips, Skull point cover, skull gas cap, RunRoader exhaust pipes, pullback drag bars, etc…
the .007 shim is to take up side play,on the kicker shaft.a,worn bushing in the ratchet gear is the usual cause of kicker slip.DR DICK cover's all the bases,in the link provided.
The 007 shims, according to the FSM, are needed only of parts are worn.
