Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE FORUM > Sportster Motorcycle Intake and Exhaust > Paying Taxes
Paying Taxes Got questions, tips or advice???
0 Clutch lever pull effort
Last Post: Centennial Sportster
0 su carb question
6 SPORTY BOBBER PICTURES
Last Post: Bryan83taco
0 Psychedelic '70s SPortster Chopper Pictures
0 What engine oil do you use?
Last Post: TUCCI
0 Too HOT to ride?
Last Post: PetesPonies
0 how do eat an elephant,,
Last Post: cazz1000
0 How tricky is it to replace dipstick trim from oil tank?
Last Post: burely
0 Buell special
0 Happy Birthday Mrs. Folkie.
0 Another clutch Question
Last Post: wrkdWS6
0 CV Carb - Transfer Ports
Last Post: XL Ed
0 Cleaning clutch
Last Post: tussuck
0 my recent ebay purchase
2 My 1275 Hammer Conversion..
Last Post: wrkdWS6
0 Iron-shed
Last Post: smokey 2
0 Frame bracket
0 top end noise
Last Post: lostNdallas
jetting, problems, stage 1
Old 7th February 2016
shtbasket shtbasket is offline
Sportster/Buell Model: 1200XLH
shtbasket is an unknown quantity at this point
Default Some jetting issues?
So I have a 2000 1200XLH, 2'' drag pipes with reversion cones and a high flow air box mod on the cheap (hacked off most of the box)
I switched to these pipes from stock about a year ago without rejetting and lost a little torque, but after wrapping them a few days ago my bike ran REAL lean..? This was before my airbox changes. I rejetted with 180/48 and it ran like a champ until I modded my airbox. Now I am sort of lugging in my midrange (not sure if lugging is the right word, but it seems like a sort of stall in acceleration). The plugs read okay, maybe a little lean but not too bad.
Also getting a backfire upon shutoff
1) Should I go up on my main jet or should I be looking for other problems?
2) Is needle height a factor I should be considering?
3) Anyone else ever experienced this sort of problem just from wrapping the pipes?
Any info is REALLY appreciated. I'm pretty new to this so don't tear me up if my **** is ****ed up
Old 24th July 2016
jstoll's Avatar
jstoll jstoll is offline
Sportster/Buell Model: XL1200Frankenbike
jstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant futurejstoll has a brilliant future
https://www.youtube.com/watch?v=KjKUKhHQLHg
S&Ss 2 cents :-)
JAK
[SIGPIC][/SIGPIC]
05 XL1200F
Frankenbike
Hammer 1250 11:1 30* pistons
Hammer Crush Head service
Mikuni HSR42
Hammer Impact Air Cleaner
SE 575 cams
XR crank
Energy One clutch
07+oil pump
Patriot Defender
TC88A with custom mapping
Old 7th August 2016
einheit 13's Avatar
einheit 13 einheit 13 is offline
Senior Master Bike Builder
Sportster/Buell Model #2: 883/1200 Hugger
Sportster/Buell Year #2: 1991
Other Motorcycle Model: Bonneville America (904)
einheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to alleinheit 13 is a name known to all
Your plugs probably aren't lean. 48/180 on a stock 1200 is plenty. The 2" pipes with no baffles is your issues. Torque cones really don't do much and could care less what others have 'shown'. I have used them on all kinds of bikes and they barely show up as any improvement until some form of baffle, step, or even lollipops are installed. Your 180 main is fine and you haven't changed the needle yet either. You are probably experiencing reversion around 3000-3500 where the bike stumbles. Your exhaust is the reason. Get some Khrome Werks drag baffles and a new needle.
And yes, all of your 'power' has moved farther up the rev range with drag pipes.
Life may begin at 30, but it really interesting around 150!
