0 EFI hose clamps
Last Post: smm1200
0 Clutchlite ramps with pictures
0 EFI fuel tank hose fail
Last Post: smm1200
0 Removing oil pump
0 In tank pump and filter work
Last Post: smm1200
4 Oil Filter
0 once a cheater always a cheater?
Last Post: tonyhds
0 Hi From NJ
0 WTF is it with these F'n rocker cover leaks!
Last Post: Kawa110
0 Grounded
0 Hardtail sporty ideas
4 The no-debate OIL POLL
0 What engine oil do you use?
0 Cost of ejikation
Last Post: shooterj2003
0 Cheap Generator Source?
0 Sticky Valve fix
Last Post: Sadsack
0 Ride Report 2019 Black Hills, Grand Teton Mtns., Rocky Mountain Ntl. Park
0 Roland Sands Design Nostalgia Air Cleaner Black Ops
Last Post: darthrinzler
0 Sportster Spoked Wheel Options
Last Post: Desertfox
0 Iron OEM Black Exhaust
0 OEM Satin Black Mirrors
0 Coil Relocation Bracket w/ Satin Black Cloth Cables
Old 19th July 2016
sportsterdoc's Avatar
Originally Posted by splineman View Post
I am going to poke around a bit more to check my electrics out, seems vibration may play a part as well with rubbing.
Vibration?!
On a Sportster??!!
Old 15th May 2017
taco taco is offline
Sportster/Buell Model: xl883 iron
Sportster/Buell Year: 2014
taco has disabled reputation
Thanks sportsterdoc for giving me some ideas on how to fix my sons 2007 custom low. my boy thought his battery was bad (slow cranking)so he replaced battery. lite came on during a short ride a day after, so he stopped by a shop they said vregulator bad replaced, fine for 3 to 4 days, lite is back on when he came over for mothersday. i checked voltage at the battery charger plug , key off 12.6, on12.4 , running 12.2, i told him not charging and i really need a trouble shootin guide. Where to find one? I thought ... let me look here and YOU DID IT !!
Havent used it yet but really thanks for a starting point and what to look for.
Old 15th May 2017
Let us know what you find.
The regulator ground should be 0.1 ohm or less.
That should have been checked when the regulator was replaced.
If a new regulator was not a long term fix, then also check the stator:
Measure stator resistance to ground (∞) and stator resistance (0.1 to 0.5 ohm, depending upon system), pin to pin.
22 amp system ~ 0.2 to 0.4 ohms
32 amp system ~ 0.1 to 0.2 ohms
Regulator connector 46 has two black wires to the stator. That is an easy place to check the stator resistance.
Adjacent to it is connector 77 which has two black wires from regulator to connector. On the other side of that connector is a red wire to the battery, through the maxi fuse and a black wire to the harness ground. Check the resistance of the black wire to the battery negative post. Both regulator connectors are in the front, below the oil filter.
This thread was due to a poor harness ground: http://xlforum.net/forums/s....php?t=1891463
