0 '81 swingarm internals
Last Post: Scott
Last Post: Oldmxdog61u
0 New intake flange design by Twin Motorcycles - must see
0 Cam position sensor
0 Japanese Harley?
Last Post: Veeflys
0 Good afternoon!
Last Post: Veeflys
0 Questions for the dyno gurus
0 Hello from LA
Last Post: Veeflys
0 It's me - Kokopeli.
Last Post: Veeflys
0 Polished rotor/brake pad compatability
Last Post: Firehawk
Last Post: FiftySixer
Last Post: spamer80
Last Post: Sparkes
0 Battery ?
0 Dual disc along with fork upgrade
Last Post: 883-1250
Last Post: RDHenley
Last Post: Calcustom
0 Lifters Comparison
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: toomuchstuff
0 The parts are all here, now the fun begins
Last Post: herostar
Last Post: hexnut
Last Post: ThrottleBody
Last Post: Bow only
ecm, powervision, tts, tuner, unlock
Old 16th April 2019
Lunightas Lunightas is offline
Sportster/Buell Model: XL1200N Nightster
Lunightas is a glorious beacon of lightLunightas is a glorious beacon of lightLunightas is a glorious beacon of lightLunightas is a glorious beacon of lightLunightas is a glorious beacon of lightLunightas is a glorious beacon of lightLunightas is a glorious beacon of lightLunightas is a glorious beacon of lightLunightas is a glorious beacon of lightLunightas is a glorious beacon of lightLunightas is a glorious beacon of light
Default Tuner Problems on used Bike
In 2015 I bought a 2009 Nightster from the brother of the owner. It has short shots on it. This year I finally decided to get the PV (power vision) as I add a Arlen Ness Big Sucker. I plugged in the PV and it said "Preparing ECU failed".
I called DynoJet and the immediately said that the only reason this message comes up is because the bike was previously tuned with a TTS Mastertune system and that I would need to send the ECM to TTS to have them unlock it so I can access the ECM.
I first thought I could have the dealer unlock it...so long story short, I paid $55 for the dealer to "re" tune it back to stock. But they didn't unlock it. I know it's set to stock cause I'm getting lots of pops on deceleration. I brought it home, plugge in the PV and I got the same message.
I then called TTS, and then sent in the ECM with notes and my personal info. I just spoke with TTS and they were happy to tell me that they could not recognize the lock on the ECM and that it was not their tune. So I am having them send the ECM back to me.
I just called the local HD dealer, got a short sales pitch on a SE tuner...then got a quote on a new ECM, it is $375 and the Labor (to flash or marry to my bike) is $150...so just a quick $550 (after tax) and I should be good to go.
I chose the Power vision due to the added benefits of tachometer view with B+ voltage, idle adjust, fuel gauge etc. and here's the most substantial reason, I DO NOT OWN A WINDOWS BASED COMPUTER OR LAPTOP, so I needed a unit that is self-sufficient without the use of a computer.
At this point does anyone have any suggestions for me? I pray to the internet gods to save me $550, or some amount of money at this point. It's not that I don't have the money, it's that I really don't want to spend it on this unless I absolutely have to. Plus I need to save money for the 2-into-1 exhaust I plan to put on later this summer.
Old 16th April 2019
Glamazon Glamazon is offline
Sportster/Buell Model: xl883r sold
Sportster/Buell Year: 2014
Have you a mate with a Power Vision tuner? Sure there's some here running 2 bikes from the same tuner.
Old 16th April 2019
Nope. None of my friends, or even coworkers for that matter drive a motorcycle.
How would this help anyway? At the moment, I have a ECM that is locked. I need to either unlock it, or buy a new ECM. Unless there is something I missing, or don't know.
Old 16th April 2019
ReddTigger's Avatar
Have you verified there isn't some sort of tuner already attached to the bike some where else ? this could be preventing the ecm from receiving the new information.
also the contacts on the eCM are gold plated and were only designed for 5 plug in's max.. you may be needing an ecm anyway if there was /is a piggy back system.
keep us updated.
States I've Ridden in
71.3 hp 70.8 tq
Old 16th April 2019
keep us updated.
I have not verified that there isn't some sort of tuner on it already. But if there was, wouldn't it plug into the sole J8150 connection? I plugged my PV in this connection, which was vacant when I got to it. Is there anywhere else a tuner could be hooked up?
What you're bringing up sounds like it could* be a possibility, so I'll entertain this thought. And at the moment, I have to believe that this bike is tuned with something other than dynojet, or TTS, or SE...I throw SE in there since I already brought it into the dealer for them to reset to stock, but I suppose that doesn't mean "unlock" now does it....hmmm...
I just hope I can plug in the ECM and ride my bike to the dealer, I don't want to have to tow it there.
I will for sure bring this (thread) to closure, I was surprised I couldn't find something more specific to my situation when I was searching the internet previously. I'd like to help others in the future.
Old 16th April 2019
ReddTigger's Avatar
if you disconnected the ecm, there should be a factory connector going directly into the wiring harness, if this connector goes into another unit, box or whatnot then you probably have a piggyback system (goes between factory harness and ecm)
Old 16th April 2019
Now we have something. I'll check this out tonight, and report back....I hope I find something.
5" of snow last Thursday, 65 and sunny today, Getting antsy.
Old 16th April 2019
SportyHD SportyHD is offline
SportyHD is an unknown quantity at this point
Might sound stupid, but do you have the run/kill switch to run? My power vision fails to connect if not in the run position. Would be awesome if it’s this simple.
Old 16th April 2019
Unfortunately this is not it, I have in fact rode the bike with the PV connected and powered up just to see if I could still see basic info like the Tach etc. but nope, all I could see is the error message during my ride. Thanks anyway, always worth a shot!
Old 16th April 2019
Folkie's Avatar
Folkie Folkie is offline
Brass Nut
Sportster/Buell Year: 2015
Lunightas, you started your thread in the 'Forum FAQ / How To' section, which is for posts about the Forum, and how to use the forum functions, so I'll move it to the 'Electrical and Ignition' section.
Folkie
South East England Riders
