0 Trans corner fix
0 Too HOT to ride?
Last Post: Racepres
0 Frankenbrakes
Last Post: Segway
0 high milage sportsters
Last Post: doc martin
0 Swingarm bearings - boy I'm glad I looked at them
Last Post: 1Scooter
0 Bigger rear Pulley
0 wtb - swingarm pivot locknut
Last Post: jsandidge
0 Cough and sputter resolved
0 Who Runs Turn Signals?
Last Post: Gpa
0 Modify my dyna 2ki ignition
0 Still having trouble starting the 61xlh
0 cleaning method for cases
0 photo size
Last Post: stikflote
0 Stock Shocks/Oil Pump
2 My 1275 Hammer Conversion..
0 TC88a DIY Power adapter ?
0 Tank Paint Ideas
0 Hello from Northern Alberta
0 Quick brake question...
Last Post: robbie202
0 Figure Machine external breather
Last Post: Bryan83taco
0 V&H slip on twin slash
Last Post: Jack250
stroker ace (80), beunme (60)
Old 25th May 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Default DTC codes P0373, U1016
Today I noticed my speedo was dropping to 0 or partially dropping then bouncing back up. Doing this intermittently. Also noticed it running a little rougher once up to operating temp recently.
So I check my codes and sure enough. U1016 loss of serial data, vehicle speed, tssm... and P0373 CKP sensor intermittent.
So I pull the crank position sensor and clean the oil off it, clear both codes and drive it a block and the p0373 code is back. I replaced it last year suspecting an issue even tho I never had the code.
Could it bad all of a sudden with such few miles? Could these 2 codes have a common cause? Cuz here's another thing I noticed when pulling the #2 pin from the ICM connector to replace it with the white wire for the tc88a the other day. The wire below pin 2, the data link wire I think(light green with a stripe)has a good kink in it just behind the connector. I was quite careful with the pin 2 removal because of it in fact thinking the wire inside the insulation could very well be partially broke. Almost has to be by the looks of it but everything worked so I dismissed it but kept it in mind. Could/would this wire be the cause of either or both of these codes? But the ckp sensor has it's own 2 pins, + and - and the vss has one.
Old 25th May 2019
Toejam503's Avatar
Air-Cooled Forever
Sportster/Buell Year #2: 1981
Double check the battery connections, I ended up having to retighten mine after the first 100 mi. on that new battery I got.
Old 25th May 2019
rocketmangb's Avatar
my speedo will come up in-op on start up occasionally !
The TC88A will throw a phantom P0373 !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 25th May 2019
60Gunner's Avatar
Chief of Security
Well that's good to know!!! Shoulda known when it came back immediately on a cooled down motor.
I'll double check my ground cable toejam.
Old 25th May 2019
rejeanprimeau's Avatar
TC88A send code, don't worry.
