Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Organize a Group Buy
Organize a Group Buy Here is where you can organize a group buy. Anyone can organize a group buy to include commerical vendors. This is only section that non-supporting vendors may mention their products but only in conjunctions with a group buy.
Last Post: brixtonanima
0 Clutch cable help (length)
0 2019 xl1200 suspension upgrade
Last Post: Bob F
0 Clutch spring tool/pinion gear tool
0 Magneto upgrade questions
0 2006 883 pops the maxi fuse after battery change
Last Post: Florida Rebel
0 TSM / TSSM / HFSM - How to disable alarm and/or replace unit
14 Installed Vulcan 3 Degree Raked Cups
Last Post: EDLC
0 Check Engine - PCM - Battery problem
0 Diagnostic code ?
Last Post: GorilladaHun
Last Post: spamer80
0 2010 Sporty will not fire! Tried everything, HELP!!!
0 Oil Leak ??????
0 1970-71 XL Fuel Tank ?
Last Post: Parker 1000
4 greetings from quarantine!
Last Post: rocketnorton
0 Who runs 70wt. oil
0 Floating front disc
0 ***DK Custom Footpegs - Shift Pegs - Highway Pegs***
0 A few more filter options
ralphy, rpcycle (69), shag (67), roadcapDen (66), oedius (63), Coolride (58), 1965XLCH (54), fingerpie (49), Pacer88888 (48), Smitty001 (42), wiccaboa (42), Homiejaime (34), Popedizzle (31), Moker (17)
Old 17th December 2008
Coxbow's Avatar
Coxbow Coxbow is offline
Sportster/Buell Model: 1200 Kustom
Coxbow is a splendid one to beholdCoxbow is a splendid one to beholdCoxbow is a splendid one to beholdCoxbow is a splendid one to beholdCoxbow is a splendid one to beholdCoxbow is a splendid one to beholdCoxbow is a splendid one to beholdCoxbow is a splendid one to beholdCoxbow is a splendid one to beholdCoxbow is a splendid one to beholdCoxbow is a splendid one to behold
that won't be easy...
2003 anniversary edition Custom – open pipes – Mikuni 42 – 150 tire – mods in prep…
HORN BROKEN WATCH FOR FINGER...
jarhead08's Avatar
jarhead08 jarhead08 is offline
Sportster/Buell Model: Sportster Custom 1200
jarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura aboutjarhead08 has a spectacular aura about
Default hows it work?
How does it install??
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
You have to cut one inch off your right bar, figure a exit point out of the bars, and run a set screw, through the bars into the grip boss.
capttawes's Avatar
capttawes capttawes is offline
capttawes is on a distinguished roadcapttawes is on a distinguished roadcapttawes is on a distinguished roadcapttawes is on a distinguished road
If I recall, you cut the end of the bars off, insert throttle assembly, drill bars and its held in by set screws.
Matt
jarhead08's Avatar
kewl beans
snowman's Avatar
snowman snowman is offline
Actually you cut almost 4" off the throttle side, install and drill hole for the set screw. If you look at the part, the smaller section goes into the handlebar. The screw holds the part in the bar and your grip goes over the outer slide to work the "magic"...
--Russ--
U.S. Army Veteran
***RIP***
--Mr. JIMI
--JOHNNY G
--BryanEOD
oldmule's Avatar
oldmule oldmule is offline
Sportster/Buell Model: Buell M2 Cyclone
Sportster/Buell Model #2: XLCH 1000 - HT Chopper
Sportster/Buell Year #2: 1977
Other Motorcycle Model: Harley FXRS
Other Motorcycle Year: 1985
oldmule is on a distinguished roadoldmule is on a distinguished roadoldmule is on a distinguished roadoldmule is on a distinguished roadoldmule is on a distinguished road
I'm in for one as well.
I can pay up any time the $ is needed. I'd like to get it done in Jan if possible.
One thing we need to check on is the cable, my understanding is since we will use a single it will need to be about 6" shorter than the ones we have. They may sell the cable as a side thing...... Personally, that's just a minor thing IMO
Knowledge not shared is knowledge lost.
snowman's Avatar
I talked to Exile and they will give us a $159 each price if we can do 10 at once.
We'll shoot for that and do it around Jan 15th.
Here's the deal with the cable:
This assembly will allow you to route your throttle cable through your handlebars. It converts your carburetor to single cable action. Provided the cable is routed smoothly, then S&S, Mikuni, etc., carbs will still snap shut when the throttle is released. The upper end of the throttle cable wire is clamped into the barrel of the assembly and does not need a ferrule on that end. This means that it is very simple to modify one of your existing throttle cables to work with this assembly. Alternatively you can use any other throttle cable, provided one end is compatible with your carburetor and the cable is long enough. We offer an over-length throttle cable kit.
I'm planning on trimming mine...
Coxbow's Avatar
Snowman, I'm just thinking about something, you said you'll take the Road6custom bars, are you talking about the apes ? 'cause those bars have an angle close to 90° at the top, and an internal cable can't handle that, well that's what I've heard anyway !
Can somebody confirm this ?
4thesporty's Avatar
4thesporty 4thesporty is offline
Sportster/Buell Model: 883xl
4thesporty is an unknown quantity at this point
That's a good point, as i have his 16"ers. It seems that somebody would make a cable that is small enough to be flexible, yet still strong enough not to break. I know that my stock cables didn't take much of a bend at all without binding. Time to start the research...
Adam
2005 883XL, Vivid Black
