Go Back   The Sportster and Buell Motorcycle Forum - The XLFORUM® > SPORTSTER MOTORCYCLE & BUELL MOTORCYCLE FORUM - GENERAL DISCUSSION > Riding Tips & Safety Advice
Riding Tips & Safety Advice Got a question about your riding technique or safety issues?
Last Post: Blackbenny
0 TSM / TSSM / HFSM - How to disable alarm and/or replace unit
Last Post: caffieneracer
Last Post: 83XLX
0 Floating front disc
Last Post: Bryan83taco
0 MC lift table modification
Last Post: xraytoken
Last Post: duffy
Last Post: thecarnie
4 greetings from quarantine!
9 CV carburetor gurus...
Last Post: Dougray
Last Post: 83XLX
0 1970-71 XL Fuel Tank ?
Last Post: 72 Ironhead XLH
14 Installed Vulcan 3 Degree Raked Cups
0 Diagnostic code ?
0 Resto-Repair 84 ironhead
0 Who runs 70wt. oil
  #61
Old 9th January 2013
ka07tar's Avatar
ka07tar ka07tar is offline
Sportster/Buell Model: 1200N / Nightster
Sportster/Buell Model #2: 1200C / Custom
Sportster/Buell Year #2: 1996
Other Motorcycle Model: FLHRC / Road King
Other Motorcycle Year: 2008
ka07tar will become famous soon enoughka07tar will become famous soon enoughka07tar will become famous soon enoughka07tar will become famous soon enoughka07tar will become famous soon enoughka07tar will become famous soon enoughka07tar will become famous soon enough
I use the standard yellow foam cylinder type earplugs when wearing a half helmet. But to avoid them poking out, I cut them in half. Cuts down on wind noise a lot but you can still hear normal traffic noises with no problem, and the speakers on the road king. Full face I don't bother with because it cuts down by itself.
Old 7th June 2019
alaxjordan0's Avatar
alaxjordan0 alaxjordan0 is offline
Sportster/Buell Model: XR1200
alaxjordan0 is an unknown quantity at this point
My suggestion is you can use a helmet for your safety purpose because It is necessary to use, but if you want to protect your hearing from wind noise and other sources then you need to use custom ear plugs because custom earplugs will fit your ears and it will give you 100% hearing protection. Every motorcyclist needs to protect hearing while riding otherwise they will put into a huge hearing loss problem, as a result, they will suffer tinnitus.
Noone wants to get tinnitus problem because it will kill you day by day. And you won't live a good life. I love riding as well I was suffering from hearing loss because I never used any hearing protection devices but when I noticed my hearing problem is getting worse day by day then I decided to use custom earplugs because only custom earplugs will fit our ears. I was googling and found some hearing protection company are given below http://www.northtxhearing.com/hearing-protection.html and Big Ear Inc. I have checked their all blogs and got a lot of information about hearing protection. If you visit their website then you will get a lot of information as well.
Old 8th June 2019
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Hold on..Tinnitus is a constant companion, much like the ever beep on a gps chart plotter... Yah Yah, Yah Yah...stfu...i see the rock.
Old 8th June 2019
BWP 5p's Avatar
BWP 5p BWP 5p is offline
Sportster/Buell Model: 1200 R
I always wore ear plugs under my Full face helmets on longer rides. They really don't have to be custom made, but the soft foam ones don't work. I had some from work that seemed to have putty in them, and you could block out nearly all wind noise. They also make some that are moldable to your ear, look like a white putty. Cheap as well! I had tinnitus for years, but have been wearing hearing aids for about 3 years now and it's gone! Hearing aids are the cats a$$....if you can afford them or if your insurance will help. Mine are courtesy of Uncle Sam, through the VA.
Stuff: YES
Old 10th June 2019
wedge's Avatar
wedge wedge is offline
Suggestion #1... Pump up the Volume!
Suggestion #2... Louder Pipes!
Old 10th June 2019
60Gunner's Avatar
60Gunner 60Gunner is offline
Chief of Security
Old 11th June 2019
SLW210's Avatar
SLW210 SLW210 is offline
Sportster/Buell Model #2: FXLR Low Rider
Sportster/Buell Year #2: 2019
SLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond reputeSLW210 has a reputation beyond repute
The 3M foam plugs I wear are NRR 33.
They need to be used properly to achieve that, there are YouTube videos on how to properly wear ear plugs, most don't do it correctly.
