4 Hello from Chicago
0 Hi
0 Hi everybody!
0 Lowbrow XLR pipes
Last Post: A Seabee
0 Bulbs
Last Post: shooterj2003
0 45740-62 & 62A differences?
Last Post: Fridge
0 Need to part with my '59
0 When Were You Born?
Last Post: owlsplace
0 Question for RB racing exhaust guys/gals
Last Post: 883sporty03
0 Efi and carbs
Last Post: Thirdbrick
0 What Petcock
0 Which cams ?
Last Post: Cumofo
0 Kickstarter return spring
Last Post: JonesL
0 Sell pricing for 1979 XLS IH Sportster
Last Post: RoadsterMike
Last Post: motorend
Last Post: dieselvette
Last Post: Renecito
0 7 Dead and more wounded
0 Let's See Them R's!!
Last Post: PetesPonies
0 Riding in The Heat!
Last Post: motorend
Last Post: Clevspeed
0 Stock Seat 48!
richard rees (70), IRONHD1K (66), derekb (58), Hankrebel (43), CPurner (38), Vickers
ktate ktate is offline
Sportster/Buell Model: 1979 XLS
Sportster/Buell Model #2: 1980 XLH
Other Motorcycle Model: 1980 FLH
Other Motorcycle Year: 1978
ktate is an unknown quantity at this point
Default Another Starter that Failed to Engage
On my 1979 XL motor, I was hearing the high speed whine of a starter gear spinning without engaging the ring gear. Like so many other owners, I checked the battery, ground, wiring, and bench tested the Solenoid and Starter. All was good. I reinstalled the combo and as I was putting the primary cover on I noticed what appeared to be a washer located between the starter shaft Spacer and the starter shaft Nut. This washer/ring appears to have been material sheared from the inside of the Spacer. I’ve installed another Spacer and I’m back in business.
File Type: jpeg 3833CB3B-E57F-413C-A907-C7DB00F2D007.jpeg (82.3 KB, 24 views)
File Type: jpeg 6606D5B4-D435-42F6-8554-74B033161D4C.jpeg (51.4 KB, 25 views)
Air-Cooled Forever
+1.. Glad you found it.
