4 Hello from Chicago
0 Hi
0 Hi everybody!
0 Lowbrow XLR pipes
Last Post: A Seabee
0 Bulbs
Last Post: shooterj2003
0 45740-62 & 62A differences?
Last Post: Fridge
0 Need to part with my '59
0 When Were You Born?
Last Post: owlsplace
0 Question for RB racing exhaust guys/gals
Last Post: 883sporty03
0 Efi and carbs
Last Post: Thirdbrick
0 What Petcock
0 Which cams ?
Last Post: Cumofo
0 Kickstarter return spring
Last Post: JonesL
0 Sell pricing for 1979 XLS IH Sportster
Last Post: RoadsterMike
Last Post: motorend
Last Post: dieselvette
Last Post: Renecito
0 7 Dead and more wounded
0 Let's See Them R's!!
Last Post: PetesPonies
0 Riding in The Heat!
Last Post: motorend
Last Post: Clevspeed
0 Stock Seat 48!
richard rees (70), IRONHD1K (66), derekb (58), Hankrebel (43), CPurner (38), Vickers
Old 11th May 2019
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Year #2: 2017
Default frame links are kaput
Heya guys!
for some reason the motor-to-frame links on my 2017 roadster are bad. I took the upper one out and one of the 'eyes' is a bit loose inside the housing!
the bottom one is not as bad, but I can turn it by hand a bit... probably bad too.
guess this is the source of the nasty noise I hear when going over imperfections in the road, etc.
wtf gives? my old 2008 still has the links in perfect shape! guess mo-co changed suppliers for the worse over the years.
does anyone know a better replacement? don't want to buy new ones on HD and have them break again....
cheers
Old 11th May 2019
harley506d's Avatar
Sportster/Buell Model: 1200c
Unless you have some other mount failure causing them to take the brunt of the work, i'd say you have just been unlucky. It's a rare thing to hear of these going often so i would say replace with genuine.
Old 11th May 2019
b0fh's Avatar
$80 dollares EACH in this god forsaken country. ugh.
Old 11th May 2019
oldboy's Avatar
oldboy oldboy is offline
Other Motorcycle Year: 1974
sending a pm to you....
Old 11th May 2019
harley506d's Avatar
Hell! $38 each according to Ronnies. Probably about €50 each here.
If you do find another supplier, let us know.
Best of luck.
Old 11th May 2019
Folkie Folkie is offline
£42.54 each at Jersey H-D.
b0fh's Avatar
cost to fabricate this: $12 us dollars, with locally sourced parts. lets see how it holds up
Will1250 Will1250 is offline
Sportster/Buell Model #2: XL 1200 bitsa project
Sportster/Buell Year #2: 1986
Will1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond reputeWill1250 has a reputation beyond repute
Like your style. Be sure to let us know how it holds up.
Cheers, Will
