0 FIXED: Replcement of burned LED in indicator light board
0 Wanted (Buell Inlet Manifold)
Last Post: gusm2
0 What Carb
0 New oil tank
0 Hello from Holland
0 2007 LED Neutral etc display cluster/bar
Last Post: 45Brit
0 Reassemble engine
0 Repainted my bike
0 add oil and ride
0 The SPORTSTER car?
0 primary register screw
0 Halloween 1250 Conversion
0 One More Ohio Meet & Eat?
0 extra hole in neck web
0 Do you Run a Fuel Filter?
Last Post: FiftySixer
0 New EU rules?
  #91
Old 27th November 2010
rottenralph's Avatar
Buell, I did the V&H with a twist. I have the same seat in the garage. I cut mine done since it is made for a peanut tank.
Old 24th December 2010
Hammerwoman Hammerwoman is offline
Other Motorcycle Model: BMW F800GT
Other Motorcycle Year: 2014
Hammerwoman has much to be proud ofHammerwoman has much to be proud ofHammerwoman has much to be proud ofHammerwoman has much to be proud ofHammerwoman has much to be proud ofHammerwoman has much to be proud ofHammerwoman has much to be proud ofHammerwoman has much to be proud ofHammerwoman has much to be proud ofHammerwoman has much to be proud ofHammerwoman has much to be proud of
Still love the SuperTrapp on my '01 1200S. . . here we are, going into Turn 6 at NHMS, back on the gas, suspension squashed, bellowing gloriously at the Ducatis around me. . .
Old 3rd November 2013
brocluno brocluno is offline
brocluno is a glorious beacon of lightbrocluno is a glorious beacon of lightbrocluno is a glorious beacon of lightbrocluno is a glorious beacon of lightbrocluno is a glorious beacon of lightbrocluno is a glorious beacon of lightbrocluno is a glorious beacon of lightbrocluno is a glorious beacon of lightbrocluno is a glorious beacon of lightbrocluno is a glorious beacon of lightbrocluno is a glorious beacon of light
Seriously cool
Old 3rd December 2013
BobWLR's Avatar
BobWLR BobWLR is offline
BobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of lightBobWLR is a glorious beacon of light
Always wanted that Supertrapp pipe, recommended by local racer types. Ended up with an Ebayed stock HD 2002 883R 2-1 pipe. It's made for mids but several riders here have adapted it to forwards with just a homemade brake rod and peg extention.
mmoran33 mmoran33 is offline
Sportster/Buell Model: XL883L
Sportster/Buell Year: 2012
mmoran33 is an unknown quantity at this point
want an RB racing 2:1. is it still considered one of the best?
steelworker's Avatar
Other Motorcycle Year: 2016
I've been ogling a 2-1 from MotorStage of Japan. seems they make two versions - one steeply upswept and the other less so. Click here and scroll half way down the page. MotorStage also make a nice looking upswept 2-2 system. Their systems have a Supertrapp-style internal disc system, with a reverse cone cover. All these systems seem to be available for rigid-mount and rubbermount Sporties.
Here's the 2-2 in action...
MOTORSTAGE 2-2
lso from Japan is the Bossley Reventon 2-1. There are high- and low-level versions. Low level's no good for me, as it would interfere with rearsets. Again, it seems to be available for rigid- and rubbermount Sporties. A couple of vids...
Bossley High Level
Bossley Low Level
I have no idea how any of these systems perform. They all look like they'll give decent ground clearance. The MotorStage systems look like they'll be pillion-friendly for rubbermount pilots, but I'm not sure about rigid mounts. With the Bossley systems, I'd guess you're flying solo.
Other options include...
Harris Pipes from NZ, who make good looking 2-1 low level and 2-2 high level pipes for Sporties.
K-Factory 2-1 from Japan.
DLIVE Sports Line and Street Line (presumably loud and baffled versions) from Japan. Being both titanium and Japanese, they're expensive. Looks like they're only available for '07-up rubbermounts.
Old 28th December 2013
norway norway is offline
Sportster/Buell Model: Iron
norway is an unknown quantity at this point
Old 12th May 2017
vagrant318 vagrant318 is offline
Sportster/Buell Year: 95
vagrant318 has disabled reputation
Originally Posted by norway View Post
Yeah I know old thread but that is sweet!
