0 New sportster in HD Research Survey
Last Post: slow883jmark
0 1981 Ironhead Dual disk question
Last Post: Tjfortyeight
0 Ironhead 1984 trouble shooting
Last Post: joes95bobber
0 Air Filter / Fuel Filter on a 2005 XL1200C
Last Post: Jerico
0 What Carb
0 Sportster Seat For Sale
Last Post: XM381
0 Fyi
Last Post: 1200CustomHD
0 80 sportster coil replacement ohms questions
Last Post: blk80bike
Last Post: jbradley46
0 Help with oil pump drive gear
0 XLFORUM quit smoking thread
Last Post: XL1275
0 Replace sprocket
0 My 900: half-H, half-CH
Last Post: Parker 1000
0 stumble
0 FAF Sporties
Last Post: Smokin Sam
Last Post: bklyngeezer
0 1992 Sportster indicator module
0 Repainted my bike
Last Post: Samedward
0 My Cafe Build...2002 883R
0 Do people notice your bike?
Last Post: commando57
Last Post: flak monkey
0 Removing transmission 1973 XLH
Last Post: Beary
0 Disassemble tranny HELP
Last Post: Mike1nw
0 Engine apart
Last Post: Mike1nw
0 add oil and ride
irvingjr (72), 909XR (63), Ghost_FL (61), mark R (60), TWISTED (47), spade (45), Drivethis29 (40), dodgetrucken (35)
noise, ping, rod knock, sportster
Old 22nd May 2018
BradX13 BradX13 is offline
BradX13 is a splendid one to beholdBradX13 is a splendid one to beholdBradX13 is a splendid one to beholdBradX13 is a splendid one to beholdBradX13 is a splendid one to beholdBradX13 is a splendid one to beholdBradX13 is a splendid one to beholdBradX13 is a splendid one to beholdBradX13 is a splendid one to beholdBradX13 is a splendid one to beholdBradX13 is a splendid one to behold
Default Diagnostic help (Pinging)
I have a 94 xlh1200 and just this season it has been making what I believe is a pinging noise. I run 93 octane fuel. Can anyone verify this or point me in the right direction.
Old 22nd May 2018
https://youtu.be/KWinUBYN67Y
Old 22nd May 2018
How long have you had the bike?
Did a tune up recently (like this season)?
Any other 'work' of any kind done on the bike this season before the problem...
Exhaust change? Air Filter change? Carb adjustments?
A lean condition will ping under load - Have you looked at the spark plugs? White-ish?
Too much advance will ping under load - Have you changed the timing or anything related to the ignition circuit? VOES? The timing is not likely to have changed on it's own, but have you checked the timing?
Elevated heat - like unusually warm weather that the bike was not tuned for...
A lean condition can be caused by air intake leaks - Have you pulled the carb & manifold and replaced the seals - this might help and should be done anyway if they are older than 3-5 years...
2 Relax
Old 22nd May 2018
jzink0883's Avatar
Master Bike Builder
Sportster/Buell Year #2: 1998
BradX13,
Don’t delay addressing a ping condition. See below for my experience with “slight” pinging on my ‘98 XLH1200.
I asked about the ping on my new ‘98 XLH1200 at all my maintenance visits during the first year I owned it. I was told “That’s normal. All Sportsters do that.” The rear piston and cylinder let go at 11.5k miles, just shy of the end of the factory warranty. After some back and forth between me, the dealer, and the factory, the engine was repaired under warranty.
Riding home from the dealer, I could still hear the ping.
Per info I got from the XL-List at sportster.org, I did the following:
- Adjusted the timing so that the timing marks were at the front (“retarded”) edge of the timing hole
- Replaced the spring in the VOES switch with spring P/N 9435K75 (0.875” long, 0.36” OD, .032 wire diameter) from mcmaster.com
- Adjusted the VOES screw so that the ignition module didn’t switch to the light-load curve until the vacuum was 7” Hg (OEM setting was 3.75” Hg)
The engine then ran fine for over 45K more miles until I traded it in on my ‘15 CP.
More details at this thread: http://xlforum.net/forums/showthread...es#post5433455
Old 22nd May 2018
The bike was passed down to me 3 years ago when my father passed. I just did a full tune up but the issue was there before I did that and is still there. I performed a plug chop and the plugs look brand new still. The timing has not been touched since I've owned the bike. It started after I moved back to New Hampshire. It normally only starts happening when it's warmed up. Thank you for the replies.
Old 22nd May 2018
Originally Posted by BradX13 View Post
The bike was passed down to me 3 years ago when my father passed. <SNIP> It started after I moved back to New Hampshire. <SNIP> It normally only starts happening when it's warmed up.
Might be a clue - Moved from where?
Temperature change - Elevation change
1) What size pilot jet is in there?
2) How many turns out on the Idle Mixture Screw
3) What needle are you using?
4) Does this carb have any Dynojet parts?
Here's the Sportsterpedia section on the CV40 carb:
http://sportsterpedia.com/doku.php/t...40_carburetors
Carefully read over this... Then record all the parts in the carb - Take pictures if you can...
Beg/borrow/buy a timing light and clear plug for the timing hole - I would definitely check the timing...
Here's the Sportsterpedia section on timing:
http://sportsterpedia.com/doku.php/t...dels_thru_2003
Post the information and pictures here...
2 Relax
Old 22nd May 2018
Also nothing on the bike has changed since I got it other than plugs. Never had the issue before this season. I moves back up here from SC but the bike was tuned in NH. I do know I have a timing led on my ignition module.
Old 22nd May 2018
i really can not tell from the clip, it sounds to me like lifter/ valve clearance clatter.
one thing i notice around here is that the fuel sucks more so than previous, thinking now that oil price is going up, they are maxing the corn squeezing. anywho, retard the timing and see if it helps and if not, get a stethoscope.
also, run a compression test and if not in ball park leak down. if one jug is low, the other is carrying more load, so the ? is it only one or both clattering.
Old 22nd May 2018
That will be an aftermarket ignition - Is the ignition module self-contained in the nosecone or is it behind the triangle cover next to the battery?
2 Relax
Old 22nd May 2018
2 Relax
I have a module behind the triangle cover. Also habe a video with the bike running with cover off and led blinking
