0 Generator light q
0 S&S Super E Carb
Last Post: jp2code
0 Xl???
Last Post: 1200CustomHD
0 New to me 55kh
Last Post: thecarfarmer
Last Post: BigMek
0 Need Tuning Advice 1275 Kit 560 Cams
Last Post: XL1275
Last Post: Nitro57xl
0 so it's officially ended
Last Post: soundnav
0 is a buell a harley
0 Nup 1009 (Bearing)
0 The Sport(ster)ing Life
Last Post: Skeezix
0 Round Air Cleaner Poll
Last Post: Joe_jeep
Last Post: 77IRHD
0 Finnish custom rider
Last Post: FinnDRZ
0 AGM battery for 76' XLH
Last Post: JonesL
Old 19th September 2010
tobiism tobiism is offline
tobiism has disabled reputation
Alright, got some updated pics-
A little wheel detail
steering damper and fork brace
Rinehart 2-1 and rounded off sprocket cover, waiting on my rearsets to come in.
overall
radeschultz's Avatar
radeschultz radeschultz is offline
radeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of lightradeschultz is a glorious beacon of light
Excellent job on those rims man, you wasted no time gettin busy!
Weo's Avatar
Weo Weo is offline
Sportster/Buell Model: 883-1250
Other Motorcycle Model: 600cc CBR
Other Motorcycle Year: 1987
Weo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to allWeo is a name known to all
Really nice!
"Insert witty comment here" -1999 883-1250 XL, N4 cams, NRHS AC, ST 2-1, Golan petcock, Ricor Intiminators, aesthetic changes
Thanks guys!
Old 20th September 2010
Swede 1200S Swede 1200S is offline
Sportster/Buell Model: 1200 Sport
Swede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura aboutSwede 1200S has a spectacular aura about
Looks sweet. Keep up the good work!
It was an exciting day! Got my ZRX shocks and my rearsets. I had to clearance the hell out of the brake pedal to get it to work with this header, but it seems to work okay now. The shocks look like they are going to be perfectly sprung for me and this sporty. The bike is now officially done, for awhile anyway
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
You test ride it with this set-up yet?
Betcha it's gonna be fun!
Old 21st September 2010
DF-SLICK's Avatar
DF-SLICK DF-SLICK is offline
DF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to beholdDF-SLICK is a splendid one to behold
Hi New to Sportys, what denotes an S Model, same as the roadster?
I like the rear shocks, Expensive?
Thanks...
2005 XL1200C. Vance & Hines two into one exhaust system, Mikuni HSR42, Stainless braided Throttle and F-Brake & Clutch lines, PM Front Caliper, EBC Floating front rotor. Round NRHS Air cleaner. F/Fork Intiminators, Ricor 13.5 rear shocks, Super Brace. Works Performance Front Springs. TC88A with Rico's Jester ignition maps. NRHS Stainless Oil Filter.
There is a whole lot of "S" info right here:
http://xlforum.net/forums/s...d.php?t=431484
steelworker's Avatar
Other Motorcycle Year: 2016
S models were rigid mount, produced from '96-'03. As standard equipment, all had fully adjustable suspension front and rear, twin front disc brakes and a tachometer. From '98 on, they also had W grind cams (as fitted to modern rubbermounts), as opposed to the D grind cams fitted to other Sporties of the time; twin plugged "Lightning" cylinder heads, giving a higher compression ratio; twin spark, single fire (i.e. no wasted spark) ignition systems; a diagnostic take-off; and were more blacked out / had less chrome than other models.
