0 spin off
0 Rear pulley inner flange
0 Rear Brake Hose Discontinued -2003 Hugger
0 Buell Wheel Bearing Information
0 distributor
0 Fender strut bolt comes out and stays out
0 Buell XB top end on Sportster Who has Done It??
0 e bay deals i got past 2 weeks
Last Post: Monte03
0 Ignition circuit
0 Belt tension
Last Post: wrkdWS6
0 10 LOW & NO COST Ways to Improve Comfort On Your Harley
0 Brake pedal won't activate brake light
Last Post: canoli
0 Pipes "Wheezing" on decel
Last Post: canoli
0 Therapy:
0 Massachusetts 2022
Last Post: trappnman
Posted On: 3 Days Ago
0 shift fork source?
Last Post: rocketnorton
texrex (70), jjluvstoride (57), luisbmns (52), njstoehr (46), tacho75xlh (43), 80ironhead80 (33), Xttrackerr (27)
Old 11th August 2022
That 'paperweight' looks 90% perfectly staight....
The new shifter - How will that design prevent bending the shifter shaft? Since the fold is 'forward-backward', it would seem to present the same bending force on the shifter shaft if the bike falls left... ??? Unless you manually move the folding tip every time you park it.
Curious...
For Sportster Tech Info:
Nibelungen's Avatar
i would say 80%... and notice
that's after i GENTLY straightened a bit the shaft...
just to make the bike roadworthy
with a prybar between swifter lever and primary cover...
Nibelungen's Avatar
Curious...
thinking a bit about vectors and forces...
IMO ever better than a shifter lever equipped with a fixed and long tip like all the others... either OEM or not
the bending force applied to the shifter shaft would be sure weaker compared with the one applied on a lever with a fixed and long tip... also the lever is alum...
either way... if i would be wrong... i just had bought a nice piece of work from that beautiful country of yours
rejeanprimeau's Avatar
A torch, a vise and a pipe; three minutes and a straight shaft.
Steve9's Avatar
Steve9 Steve9 is offline
Sportster/Buell Model #2: XL
Other Motorcycle Model: FXDC
You know what you are doing rejean
Steve
'01 Cyclone stock
'13 FXDC 96" stock
Nibelungen's Avatar
correct
some friends (retired) have told me...
but i am an IT guy overloaded with tasks...
and have no time for learn that skill...
also i never used a torch in my life...
so...
And, I'm talking about an acetylene-oxygen torch with at least a number 3 tip, not a 2D batteries ones like people from UK call it. LOL
Old 12th August 2022
Nibelungen's Avatar
when retired i hope to achieve a little more craftsmanship
already I have a quite furnished garage (my old man a lifetime mech)
I lack just spare time
when eventually I will be emancipated from the job
i have planned to buy a used superbike... Italian, Jap... considered even a Buell... and rebuild her like brand new in my garage
wrenching
working
learning from my mistakes
wedge's Avatar
wedge wedge is offline
Yes, like Rejean said. Save that shaft, and later when you have time use a torch to warm it up (Red) and bend it using a piece of pipe while holding the straight section in a vise. (Just be careful to protect it from the vise jaws or the seal will leak).
Old 18th August 2022
Nibelungen's Avatar
Default nice piece of work
In addition with the foldable tip... there is that groove...
so in case of a drop... is the shifter lever that may be bent and not the shaft...
like it should be
