2 Your daily tunes...
0 Touring on a Hugger
Last Post: RDHenley
0 Changing engine oil
Last Post: vagrant318
0 spark plug wire ohms
Last Post: Kbetts
0 Finding an accessory power source
0 Figure Machine external breather
0 Head bolts and conversion
0 Rocker cover torx
Last Post: Bikeaholic
0 su carb question
0 Stretched Swingarm
Last Post: Racepres
0 DYNO TEST RESULTS: SE 58mm Throttle Body
0 LED headlight caused problems
Last Post: dayypete
0 Who has gone from Jackhammer 570s to Impact 560s?
Last Post: hexnut
0 Mid West Meet & Greet
Last Post: Bow only
Last Post: koolbreeze
0 Bigger rear Pulley
0 Swingarm??
Last Post: Racepres
0 my recent ebay purchase
0 derby cover adjustment spring broke
Last Post: burely
0 Plug for Siren
0 HD spares and parts availability
Last Post: doc martin
0 LIQUIMOLY oil additive whose using it?
0 Who Runs Turn Signals?
Last Post: Tincan
Mr.Gordon, rayzer13 (57), GrumpyCoyote (51), billet93 (47), beast1 (46), Barney_rubble23 (46), DDT (42), mgaworecki (41), superman5a (39), Phoenix81 (39)
Old 31st December 2019
runnerup1 runnerup1 is offline
runnerup1 is a splendid one to beholdrunnerup1 is a splendid one to beholdrunnerup1 is a splendid one to beholdrunnerup1 is a splendid one to beholdrunnerup1 is a splendid one to beholdrunnerup1 is a splendid one to beholdrunnerup1 is a splendid one to beholdrunnerup1 is a splendid one to beholdrunnerup1 is a splendid one to beholdrunnerup1 is a splendid one to beholdrunnerup1 is a splendid one to behold
Default How to properly chop front blinkers
I can't find a good guide on how to. I bought the bike with the front turn signals gone. I added two rear LED tail lights and put in resistors but I am getting constant light, no flashing. What is the best way to get these suckers to start blinking? I have seen two and three prong flasher modules, seems the easiest way but I am not sure how to wire them up to what I have. Would it be easier to add something to the wiring for the front flashers that are now cut? Thank you in advance.
TWO TAILLIGHTS? Do you mean Turn Signals? If something else, please explain.
Here's the Sportsterpedia section on Turn Signals:
Missing a Right Front TS and using a LED for the Rear TS - You'll need two 6-ohm, 50-watt resistors wired in parallel to compensate for the missing incandescent bulbs. Wire both resistors in parallel by connecting one end of each resistor to the BROWN TS signal wire and the other end of each resistor to ground. This will current load the Turn Signal Module similar to using the incandescent bulbs.
Old 2nd January 2020
http://xlforum.net/forums/showthread.php?t=2070747
what i use on 01 sport
