0 Xl???
Last Post: SLW210
0 AHDRA Orlando speed world??
Last Post: painterdude923
Last Post: SLW210
0 Replace lifter(s) w/out teardown?
Last Post: canoli
0 Sportsters in movies and TV
Last Post: SLW210
0 TC88A update ?
Last Post: HOG63
0 72 XLCH clutch ball and ramp system
Last Post: owlsplace
0 Your never too old
0 Tuners
Last Post: Sirrom1
0 Morning default to odometer
Last Post: Eric Von Zipper
Last Post: leon bee
0 '66 XLCH Repro Bars? (VM38 Conversion Continued)
Last Post: ProLibertate
Last Post: sportymike02
Last Post: Zip1
0 Ironhead heavy duty cable amps ?
Last Post: Uberstorm
0 Xl for sale
Last Post: jeosbolt
Last Post: chardhin
0 Pawl Carrier Support Bushing ???
oldsporty1 (70), paris15 (62), thesmithiz (62), pajimmyjoe (61), chuckam (57), steve w (51), le_strike (44), Rubicon (38), r3db3ard3d (32), rortiz76 (32)
Old 28th August 2019
Pro1 Pro1 is offline
Sportster/Buell Model: 1200
Pro1 is just really nicePro1 is just really nicePro1 is just really nicePro1 is just really nicePro1 is just really nicePro1 is just really nicePro1 is just really nicePro1 is just really nicePro1 is just really nicePro1 is just really nicePro1 is just really nice
Default HELP!! Won't shift
Hi all. New here. I Need help!!! I have a 95 1200 Sportster and I can't get it to shift past 2nd. I just replaced the 5th gear output shaft and put in a new clutch pack and primary chain while I was there. After I re-installed the transmission I could turn the shift drum by hand easily. I lined up the shit pawl per the Harley book and used a thin washer and e-clip instead of the factory clip on the detent plate. all else installed per the book. Buttoned up the primary, filled w/ oil and fired it up today and can't get the thing past 2nd gear. Any ideas before I tear it back apart????
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Welcome to the XLForum.
Any binding of sifter?
Sounds like you need to open it up.
I'd put it back together in 3rd gear??
racerwill's Avatar
racerwill racerwill is offline
Sportster/Buell Model: XLRR
Sportster/Buell Year: 91
Sportster/Buell Model #2: XLH1100
Sportster/Buell Year #2: 80
racerwill has a reputation beyond reputeracerwill has a reputation beyond reputeracerwill has a reputation beyond reputeracerwill has a reputation beyond reputeracerwill has a reputation beyond reputeracerwill has a reputation beyond reputeracerwill has a reputation beyond reputeracerwill has a reputation beyond reputeracerwill has a reputation beyond reputeracerwill has a reputation beyond reputeracerwill has a reputation beyond repute
Cool
I'm thinkin' the eccentric screw on the shifter pawl is not properly adjusted.....did you adjust that in 3rd gear??did you insure the eccentric portion of the screw is at 12 o'clock and not at 6??
sounds like you need to open it up......
carry on
Ww
master wizard
RIP Mr Jimi
Blue Locktite..... I put that sh*t on everything.....
"never trade the thrills of living for the security of existence"
"All The Way"
racerwill's Avatar
Cool your first post
oh, and welcome to the forum from sunny New England, home of the worlds largest superbowl ring collection
all the help you will ever need for your Sporty is here, look around, don't be shy.... there's even an introduce yourself area
carry on
Ww
Old 29th August 2019
Thanks for the welcome and suggestions.
Racerwill - I bash on New England all the time in good fun but I have to give credit where credit is due. They've been a solid team for years and deserve the rings they have..... Dam that hurt......
I set the shift pawl up with the drill bit size called out in the factory manual (#32) w/ the trans in 3rd gear. Not sure what you mean by "eccentric screw". The 95 shift pawl is held on and adjusted by two poly lock nuts on studs in the case. The shit pawl has slots to allow adjustment between the shift fork and drum pins. I'll tear it back down this weekend and re adjust the clearance - may have to tweak it a bit.
Here's the Sportsterpedia section on the 5-speed transmission:
http://sportsterpedia.com/doku.php/t...o:transfinal03
Have a look around...
Follow the procedure in the manual carefully...
Do you have the upgraded Detent Plate - 33656-90A ???
Old 30th August 2019
racerwill's Avatar
Cool
sorry, my fault, the last 2 transmissions I went into were both Bakers, and they use the eccentric screw.....I remember on the HD 5 speed there's a small arm all the way near the case that rotates on a shaft and held in position by a very small spring...... if that spring comes off or that little arm is upside down or flipped over it won't shift up
carry on
Ww
