0 KBS tank sealer
Last Post: mrmom9r
0 Tools
Last Post: Baby883
0 Zippers 1250 kit
Last Post: seajay
0 100 vs 110 front tire
0 mainshaft rollers size
0 MS rollers way too tight
Last Post: Rolli
Last Post: PappaBravo
0 Newbie
Last Post: BitterOldMan
Last Post: jcro61
0 OEM Headlight Bucket?
Last Post: Mission1
0 my sunday driver...
0 -65A mufflers
0 my daily driver
Last Post: webman94
0 carbs?
0 Better Brakes
0 just for my head
Last Post: Iron Chuck
0 2020 End of Year Report
0 81 parts
Last Post: kobra50
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: exexpat93
Old 24th September 2019
painterdude923's Avatar
painterdude923 painterdude923 is offline
painterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to behold
Default Starter ring gear
I had a few teeth on the ring gear broke off last year so when I had everything apart getting the trans done by R&D motorsports, I replaced the ring gear. What a PITA that was! Started having starter issues again and finally it wouldn't engage at all! Pulled the primary off and holy sh#@ the ring gear is wasted! Anyone know what is wrong? Replaced the original starter with an All balls racing starter. What could I have done wrong with the installation? Been a couple years since I replaced the original. I am cleaning up the mess and not wanting it to happen again! I could use some help please. Thanks
