0 Head Porting 101
0 SBS Project - Sportster Chop w/ Lots of Photo's
0 is a buell a harley
Last Post: Coz
0 tubing strength if pressed?
3 Shaky Dave Recovery
0 69 oil pump breather timing mark
Last Post: RDHenley
0 Blackstone HyperTek
0 Request for recommendations: Sissy Bar for chopped fender
Last Post: HUEMAN
0 Is it a carb issue
Last Post: HUEMAN
0 On starting a new thread
0 The country store
10 how low do you let it idle
Last Post: night-train
0 Electric Harley sub-forum(s)...?
Last Post: SLW210
Old 27th September 2019
edijse edijse is offline
Sportster/Buell Model: XLH 1200C
edijse is an unknown quantity at this point
Question Long crank time
Hello fellas!
About a week ago two oddities occured with my sporty. First, when I turn the key on, there is almost a minute long lag before the odometer and speedometer come on. The idiot lights are on always and everything else works fine.
About a week ago, I started to have an issue where the engine cranks for up to 20 seconds before the bike fires. Usually it fires on the first or second crank. The speed of cranking is not slowing down and it turns strong.
It's a 1999 1200 custom.
What do I need to look for? It still works but is getting me worried.
thanks in advance.
Edge
DO THE FOUR VOLTAGE TESTS - Report back with the voltage readings - they are important...
Your ground wires are located on the top rear motor mounts - Be sure they are clean & tight - Make sure the wires are not broken or frayed...
Old 29th September 2019
inline spark tester to confirm ignition during crank
if not there, check pickup, fusing/wiring and ign. module.
you might want to run compression test as low compression will cause start issues. before jumping the electronic dragon, nail all of the mechanical first.
