Last Post: rocketnorton
0 OEM Headlight Bucket?
Last Post: Mission1
0 Better Brakes
0 just for my head
Last Post: 93trident
0 Grateful Dead Timing Cover Source?
0 Brake light issues
Last Post: 45Brit
Last Post: david.hanaga
0 MS rollers way too tight
0 Newbie
Last Post: BitterOldMan
0 Oil leaks
0 Mid Control?!
Last Post: denguy
0 Holiday Sale At Hammer Performance
Last Post: Turbo Sporty 48
0 Forward controls on a 2 into 1 exhaust system.
Last Post: exexpat93
0 Chris Farley Bike
Last Post: wongjohnson
Last Post: leon bee
0 carbs?
0 Happy Thanksgiving
Last Post: bklyngeezer
0 Halloween 1250 Conversion
0 Northern Canada late 1950’s
excel50 (79), blazer95 (70), mycle1000, Barryn37 (59), QBALL (59), paulieb (58), cfranz (47), BMXATV (46), ravyn3 (41), Texas_Wild, hillpope (38)
Old 4th October 2019
HDCUSTMBUILD HDCUSTMBUILD is offline
HDCUSTMBUILD is an unknown quantity at this point
Default Suicide / Jockey Shifters No Pivots
Hi All,
So my local fabricator has come back with a 12mm steel bar nicely shaped as my hand shifter however, theres no room for a pivot meaning it will be mounted directly onto the tranny shaft.
its approx 40cm in length so was thinking about using one of those steering dampers you usually find mounted to sports bike handlebars and having this in place attached to the bar to soak up and vibration and to keep a steady back and forth movement.
Let me know your thoughts, I've seen the feedback about heavy bars mounted direct to the tranny and could cause wear on the seals and forks over time.
Finally, I've shortened my clutch cable and attached it to the existing gear shifter on left side using cable grips and springs. Its on an incline and doesn't spit out any primary fluid ... probably just!
Sent from my SM-G975F using Tapatalk
Old 5th October 2019
Glamazon Glamazon is offline
Sportster/Buell Year: 2014
I might be wrong on this, it's a long time since i was in physics class at school but won't a long lever put strain and increased wear on selectors etc as it allows more force to be transferred?
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
How is there no room for a pivot? This can be accomplished many ways. Just perform a web search for Harley suicide, jockey or hand shift and you will see many examples.
A long lever isn’t a good idea. The steering stabilizer thought may reduce random gear changes and stop the handle from rattling around. Its not going to take the load off the shaft.
Was up late last night, I made a bracket that attaches to the top right of the primary cover and the rear where the earth bolt is. I've asked the fabricator to make me another bar so I can attach the gear linkage. I've included a picture I found online showing the approach .. only difference is my 12mm bar doesn't look at pretty.
Old 20th October 2019
Air-cooled Forever
^^I LIKE that setup!^^
Old 24th November 2019
RDHenley's Avatar
RDHenley RDHenley is offline
Sportster/Buell Model: XL883C
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Street XG500
RDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond reputeRDHenley has a reputation beyond repute
Theoretically yes, but...
If you look at the difference in force you can apply with the toe of your boot vs what you can apply with a couple fingers, it should work out the same as long as you're remembering finesse and not force.
And, the longer lever would tend to make it easier to find neutral too.
