Last Post: jzink0883
Last Post: murphdog
0 Cam question
Last Post: T. Clark
0 mainshaft retaining ring by sprocket
Last Post: ericfreeman
0 strange noise in top end
0 Oil leak
Last Post: Roane
0 Old new guy
Last Post: BruceClarke9
0 Flywheel en play check 1974 Sportster
0 Roadster Speedometer Light Sensor
Last Post: felis
0 Bike Beast
0 BSA to be reborn...
0 mainshaft rollers size
0 random rattle
0 Loses Power
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: iBloke
0 BEWARE Of SCAMMERS!
0 In search of XR1000 parts
Last Post: LenC
0 84 rear wheel spacer confusion
Last Post: 83XLX
collinsb (76), bulldog1200C (62), DrBlond (57), Moonpie (55), mercybeat (50), mogwai (46), Ratster, E.MCCOLLOM (43)
Old 11th October 2019
canoli's Avatar
canoli canoli is offline
Default 1992 front Caliper Mounting Braket???
Striking out everywhere trying to find this part. J&P, Revzilla, St. Charles Harley, Lowboy, Bikerdirect...sold out or backordered. I came across The Manual Store (great selection of manuals, unfortunately not the Electrical for Harleys) - same story, backordered.
The Harley OEM # is 44072-92 and it's generally called the Caliper Mounting Bracket. It holds the "floating" brake pad - the one the piston contacts.
Apparently I didn't line up the rivet correctly with the guide pin when I changed my pads a few weeks ago. I looked at it the other day (b/c the brakes were squealing) and the rivet is chewed up a bit, to the point where it won't seat flush to the pin now. I can file it some more but I'd rather just replace it.
Here's a picture of a new one. If you guys happen to know a good online parts source, or any suggestions for the real world...
Thanks!
http://xlforum.net/forums/attachment...1&d=1570757174
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Try shop.newcastlehd.com or surdyke
A used caliper on eBay is $30-$40 with shipping.
canoli's Avatar
thanks I'll give them a try. I did find someone selling a new one on ebay but they wanted $53 + $7.99 shipping. When they're in stock they sell for about $30 new so I'll wait a bit before paying $60.
Thanks again!
I don't see that they have any listed, but you might contact these folks:
https://pinwallcycle.com
canoli's Avatar
Thank you IXL I'll try them too... strange how the places that stock them are all "sold out" or have them backordered. I know 1992 is going back a bit but it's not that long in Harley years...I always thought there was a healthy supply of NOS out there but this pad holder is really tough to find.
Thanks again!
Ronnie's shows an upgraded part number for 1992 Sportster 1200.
http://partsfinder.onlinemicrofiche....PER%20ASSEMBLY
13 44060-83A* BRACKET, CALIPER MOUNTING* $17.49
I'm not sure why - but other references use the 44072-92A number for 1992 Maybe Ronnie's is wrong on this one...
Did you try running the -92A part number??
Surdyke shows the -92A for $28.37 - no indication of not available -
