0 Fact or fiction?
Last Post: rocketnorton
0 You can't tour on that!!!
Last Post: RDHenley
Last Post: herostar
Last Post: bikeridermark
0 Black Friday/Cyber Monday Showoff Thread
Last Post: herostar
0 XLCH Plunger Seat Kit
Last Post: FatboyBill
Last Post: fafcpa
0 hi all
Last Post: early iron
0 Swingarms
0 the roadster make more power ?
0 question for our machinists
0 supply oil line seeping
0 Question on priming motor for kickstart
0 Interview of My Expieriences Riding in the Iron Butt Rally
0 Hydraulic Lift For XL
0 3.5" straight riser
0 Cometic Air Cleaner Gasket?
0 Fork Upgrade to 39mm. Is This Possible/Wise
Last Post: Nacs
Last Post: olrider
5 Crankcase Oil Drain Plug
0 Winter riding clothes
Old 13th October 2019
doodah man's Avatar
I would recommend not adjusting your floats (yes, plural) until you have exhausted other ideas. For instance, if there is any rust/crud in the tank that is migrating to the carb, it should be dealt with first...
http://www.mikuni.com/pdf/vmmanual.pdf
mickey t's Avatar
mickey t mickey t is offline
Sportster/Buell Year: 79
U hear ya...brand new gas tank too
Old 14th October 2019
Kingrabbit's Avatar
Kingrabbit Kingrabbit is offline
Sportster/Buell Year: 1973
Other Motorcycle Model: Honda CB550
Other Motorcycle Year: 1974
Kingrabbit is an unknown quantity at this point
Default Disassemble
Once you pull a carburetor off and disassemble it that will banish the bogey man of fear forever. It’s not complex.
Go for it. Carefully and methodically.
I vote for float height.
IronMick's Avatar
IronMick IronMick is offline
Rider Of The Iron Steed
There somewhere is a series of posts bu XLForum member piniongear on adjusting the float on a VM38-9. My recollection is that it is a more precise process than on the Keihin carbs.
Mick
IronHead Forever!
Visit Mick's WebSite
[And Check Out My Autobiog]
I've brought what I've found so far into the Sportsterpedia on the VM carbs.
Tuning and adjustments:
http://sportsterpedia.com/doku.php/techtalk:ref:carb01i
Most everything there is from piniongear I believe.
mickey t's Avatar
Great thank you
mickey t's Avatar
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
The float height cannot change by itself. Did the pissing out of the carb just arise? If the float height was off, it would have been leaking from day one. Isnt this the same bike you have been trying to get the timing and clutch figured out? It would have been pissing out throughout all of that time if you had the petcock on with fuel in the tank. Clean the bowl and needle out first before you change the height. Address one issue at a time.
mickey t's Avatar
Yes...same bike n yes this just happened..would leaving the petcock on cause this as well?
It should not happen out of no where, if your float needle is clean and functioning and your tank is properly vented.
Cap vented??
