0 Cases Full Of Oil
0 Blackstone HyperTek
0 We were robbed at gun-point...
3 Shaky Dave Recovery
0 Deer hunting at stairman's.
0 69 oil pump breather timing mark
Last Post: 72 Ironhead XLH
0 BETTER Brakes for $214
0 tubing strength if pressed?
Last Post: JonesL
0 Timing
0 super b overflow
Last Post: rickmodee
0 Buy A new battery
0 On starting a new thread
0 Powerraythor conversion
Last Post: dewjantim
Last Post: Racepres
0 Speed
Last Post: eskimo619
0 Hello from Long Island, New York
Last Post: TheBreeze
0 To Lace or Not to Lace, or While We're Doing This...
0 Electric Harley sub-forum(s)...?
Old 13th October 2019
Clevspeed's Avatar
Clevspeed Clevspeed is offline
Sportster/Buell Model: 2003 Sportster 883R/1200
Clevspeed has disabled reputation
Default Lifters
Do Sportsters have Lifter problems like the Big Twins?
883RS/1250
What problem is that?
Clevspeed's Avatar
Bearings on Rollers!
Not normally a problem on 91-up models as far as I know.
The 86-90 models had the big rollers and bearing failures sometimes.
rocketmangb's Avatar
Sportsters had the .904 lifters until 2000
So whats the problem ?
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Three Sportsters, 2000, 2004 and 2006,over 300,000 miles and a total of one tappet failure. I don’t consider it a problem.
Exact same lifter a Small Block Chevy uses since they went to Roller Cams
Clevspeed's Avatar
I did not think it was a problem on
Sportys! I know Twin Cams recommend changing them every 25k miles!
Old 14th October 2019
Nibelungen's Avatar
really?
never heard about...
if the end justifies the means... then who does justify the end?
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
Twin Cams have a host of cam, lifer and timing chain issues.
BT EVO's fail the front exhaust lifter with a lot of miles.
M8's have some issues too.
The EVO Sportster is the most reliable engine Harley makes!
Sleepy Labeef rides again!
