0 Newbie
Last Post: randy3934
Last Post: wongjohnson
0 OEM Headlight Bucket?
0 Chris Farley Bike
0 Mid Control?!
Last Post: MikeBel
Last Post: leon bee
0 MS rollers way too tight
0 carbs?
0 Happy Thanksgiving
Last Post: bklyngeezer
0 Grateful Dead Timing Cover Source?
0 Halloween 1250 Conversion
0 Better Brakes
0 Northern Canada late 1950’s
0 Oil leaks
0 oil bag
4 1995 S2 buell
Last Post: J!nx
0 Spacer swingarm bearing
Last Post: eddie XLX
0 81 parts
Last Post: Andy Hog
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: Desertfox
0 XLCR replica in progress
Last Post: rg500
Last Post: XL1275
excel50 (79), blazer95 (70), mycle1000, Barryn37 (59), QBALL (59), paulieb (58), cfranz (47), BMXATV (46), ravyn3 (41), Texas_Wild, hillpope (38)
Old 19th July 2005
sportsterrific's Avatar
sportsterrific sportsterrific is offline
Sportster/Buell Model: XL50
sportsterrific will become famous soon enoughsportsterrific will become famous soon enoughsportsterrific will become famous soon enoughsportsterrific will become famous soon enoughsportsterrific will become famous soon enoughsportsterrific will become famous soon enough
Default adjusting primary chain tension
OK, I changed my primary oil but I can't figure out how to rotate the chain so I can find the tight spot to adjust the tension. I know how to do the actual adjusting. I have a lift, but no FSM only a Haynes manual.
XL50 #494/2000 - Orange
Old 19th July 2005
cantolina's Avatar
Luvs me an artsy chick...
Sportster/Buell Year: 97
Make sure its secure...rear wheel off the ground...
Put it in 5th, and you'll be able to turn it....
Take out your plugs, might be a little easier...
~Chuck
Occam's Razor...
XLF Tuning Stickies
Old 19th July 2005
Thanks. I tried that, maybe I wasn't trying hard enough, or I should've removed the plugs. OK I have something to do tonight.
Old 19th July 2005
cantolina's Avatar
It IS a bitch.....I think someone here figured out that in 5th gear you have to get around 5 or 6 rotations to get the primary around once...
Helps if you have someone to spin the tire while you watch the primary....
Old 19th July 2005
bubbahog's Avatar
bubbahog bubbahog is offline
bubbahog is an unknown quantity at this point
Yep, it's a bear to get turning, but you're doing it right.
'04 1200 Custom
SEII Taxes paid
Amsoil all around
Old 19th July 2005
Sportster Girl's Avatar
Sportster Girl Sportster Girl is offline
Sportster Girl has disabled reputation
Hey Chuck,
I like your new avatar. Is that the expression you had on yer face when you sliced/diced Bambi's mommy?
Old 19th July 2005
hero's Avatar
hero hero is offline
Sportster/Buell Model: ex 1200 C rider
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 2010
hero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the rough
It's also possible to adjust the chain with the engine running. Carefully load it up (at operating temp) while the bike is idling in neutral until you hear a slight whine. Then slowly back the adjuster off until the whine dissapears. For peace of mind, you can back the adjuster off a further 1/8th of a turn from this point, & then lock up the nut on the adjuster. Perfect noiseless shifts & no more missing gears...
Stef.
Old 21st July 2005
Turbota's Avatar
Turbota Turbota is offline
hero ....
Now, that's the best tip I have heard in a loooong time!
When you say "load it up" ... do you mean hold the rear brake slightly while running it on a lift in gear ... maybe 1st gear would be best?
I'm just a little confused.
Thanks,
Ron
04 XL 1222R
Old 21st July 2005
Originally Posted by Sportster Girl
Hey Chuck,
Dang it SG, you beat me to it....I thought the same thing.
Now for the manditory Banna...
Old 21st July 2005
Racer X Racer X is offline
Racer X is an unknown quantity at this point
Question
I was just getting ready to tackle this service myself but got way to annoyed when the 27t torx screws stripped when taking off the cover! I managed to get to fluid changed but have been waiting to read how to adjust the chain. I like the sound of adjusting it with the bike running since I certainly don't want to take the cover off again if I don't have to! Please describe "loading it up" if you can. I read it as loading the chain by adjusting the tensioner. Is that what you mean? Does the wheel need to be spinning? Thanks for your help!
