0 72 heads, do these look normal?
0 99 sportster rims on a 09 sportster?
Last Post: WAHAPIN
0 AGM battery for 76' XLH
Last Post: Rodzilla
0 '66 XLCH VM38 Conversion
5 Red Shift cams similar to Jackhammer 570 ?
Last Post: wrkdWS6
0 $700 Ironhead ? Good value? depends who you ask
Last Post: thecarfarmer
0 "S" model specific Q&A
Last Post: webman94
Last Post: Roaldl
0 Sportster Sport 1200S '98-'03 Ignition Replacement
0 Ideal RPM
Last Post: sprink
0 1979 xlh brake pedal woes
Last Post: 1200CustomHD
0 Hurricanes
Last Post: XL Ed
0 2013 48 what would you update first?
0 Hello from Home of HD
DaddyJay, sixshooter (73), cartoad2001 (71), Dirty Ernie (65), ncpickman (59), bri1200c (57), pquirk (54), GOTWA (51), gremlinsteve (51), lbowles2 (49), Guess (41), rnaway22es, landon283 (32)
Old 24th July 2005
WinXP WinXP is offline
Sportster/Buell Model: Night Train
WinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enoughWinXP will become famous soon enough
This sounds like a great way to adjust chain. Mine has about 5k miles on it an probably needs adjusted. Would like to see more results doing it this way.
06 Night Train
95 1200 Sportster
04 1200 Sportster
09 Dyna Street Bob
Old 24th July 2005
Turbota's Avatar
Turbota Turbota is offline
Originally Posted by xena
Ron was it easy to detect the whine sound that Hero mentioned? Can I adjust it this way going by the sound alone?
xena ...
I really didn't adjust it by sound alone. In fact, I adjusted it by looking at it's movement.
I never tightened it so tight that it would start that whirring sound.
In my case, the top part of the chain was really flopping around when the bike was idling. I tightened the chain so when it was spinning, it would have just a little up and down movement (I didn't want to get it too tight), but not bouncing around.
In my case, there is no whirring sound now (so I know it's not too tight), but it ain't flopping all over the place either ..... That's about the best I can discribe it.
Again, I could never seem to get it right by trying to do it like what is shown in the Service manual. Just too much room for error ... but doing it when the engines running, you can see exactly what's going on.
Ron,
Old 24th July 2005
xena's Avatar
xena xena is offline
Assistant Administrator
Ok, well I'm going to try it Hero's way (by the sound). He says he does it that way so I trust it will work.
XLF Rules/Guidelines
XLF Guidelines II
1212 Conversion 10:1 CR
SE 497 Cams, E1 clutch, Python 3 Slip ons
TC88A running Xena's (brand new) White Tiger Map
My 1212 Conversion Thread
Old 24th July 2005
hero's Avatar
hero hero is offline
Sportster/Buell Model: ex 1200 C rider
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 2010
hero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the roughhero is a jewel in the rough
It'll be fine either way Xena, but maybe mine isn't quite as messy. Just make sure the engine is hot (operating temps), & adjust the chain little by little, allowing enough time to get your ear accustomed to all the drivetrain noise so you'll pick out the whine (sounds like a hairdryer, or a siren in the distance & will increase with engine revs) easier. When you think you've nailed it, take it for a testdrive.If the whine is still audible- loosen adjuster slightly,if the gearshift is clunky - tighten adjuster slightly.
Stef
Stef.
Old 24th July 2005
xena's Avatar
Thanks Stef. I'll give it a shot later today and will post back in case anyone else is new to this method.
Old 24th July 2005
Adjusted the primary chain hero's way. With engine running an trying to do it by sound. But my hearing is not the best anymore. So pulled the inspection cover off to check it an had to back it off a little.
Turbota is correct on fluid coming out. I might suggest a short height pan under kick stand to catch oil. I used a old beach towel on top of a piece of cardboard. With a 1" wood block under kick stand. I may have lost more than a ounce but with hot oil it is hard to tell. Added a ounce back when completed.
Thanks hero for the tip.
Old 24th July 2005
xena's Avatar
I think I've got it. Gonna ride two towns over to my friend Adams shop. He's got a 73' Sporty and he's a big time grease monkey so if it's not right he'll teach me how to adjust it by ear.
Old 25th July 2005
xena's Avatar
I did it , thanks Hero! It's perfect now. Psyched. Thanks again for the tip.
Old 25th July 2005
01Sporty's Avatar
01Sporty 01Sporty is offline
Keep On Keepin' On
Sportster/Buell Model: Pulled to the Darkside
Other Motorcycle Model: FLHTCI
01Sporty is an unknown quantity at this point
Me too, just finished, got cleaned-up and off for a the final test ride.
I did however make a clear "inspection" cover out of a small piece of plastic, I lost maybe 10 drops of fluid and it wasn't very messy... Don't ya just love Brake Cleaner?
BTW, is it usual for the adjust me to be 1 - 2 turns tighter with only 1,500 miles on it?
Thanks Hero and Turbota.
Old 13th August 2005
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
Default Primary adjusting on an '04 1200R
Stef
I'm doing my 5K service and adjusted the clutch and primary today - 'cold' like the service manual says. It seemed to be pretty close to the spec they gave. Started it and took off for a ride to get screws to replace those damn torx derby cover screws, argh!
I get where I'm going and I hear the whining. I'm going to check the adjustment with it hot and see where it falls as compared to the service manual 'hot' spec. PITA!!! Don't tell anyone I swore.
