0 Secondery Vin tag
Last Post: supermotolew
2 My 1275 Hammer Conversion..
0 Roadster - No Key Start
Last Post: Skeezix
0 mainshaft rollers size
Last Post: thefrenchowl
0 XLCR replica in progress
0 What engine oil do you use?
Last Post: SLW210
0 81 parts
Last Post: Andy Hog
0 my sunday driver...
0 Halloween 1250 Conversion
0 Top end rattle at 3000 rpm
0 Northern Canada late 1950’s
0 Cam question
Last Post: T. Clark
0 tappet/blocks fitment by year
0 MS rollers way too tight
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
  #81
Old 21st September 2011
LuxBlue's Avatar
LuxBlue LuxBlue is offline
Originally Posted by xlSleeper View Post
I finally had a chance to test mine out. I love it so far. It quiets the noise down from the primary. It also smooths things out a little. I think it was a good buy.
Nice!
Old 22nd September 2011
aemsee's Avatar
aemsee aemsee is offline
Sportster/Buell Model: xl883c
aemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond reputeaemsee has a reputation beyond repute
just installed one of these on my 07. The chain was tight almost immediately after turning the screw. No way is the spring completely unloaded. Took it out for a ride. Shifts nice, has a slight whine to it, but it didn't change when it got hot, so gonna run with it and see how it goes.
redi2ride's Avatar
redi2ride redi2ride is offline
Sportster/Buell Model: Sportster 1200cc
redi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud ofredi2ride has much to be proud of
Awesome write up. Thank you. you mentioned a whining noise ? would that be from the tension er being too tight?
"They who can give up essential liberty to obtain a little temporary safety, deserve neither liberty nor safety." -- Benjamin Franklin
Old 9th November 2011
spby52 spby52 is offline
Sportster/Buell Model: buell mutant
spby52 is an unknown quantity at this point
Default Thanks
I'm in the middle of replacing my shifter shaft and shifter pawl on a 99buell motor...def.goin look in to one of these..thanks again
Old 5th January 2013
Paul's Avatar
Paul Paul is offline
Paul has disabled reputation
I am having trouble understanding where this tensioner picks up a pressure feed to operate. What am I missing?
Paladin "Have Bike Will Travel"
steelworker's Avatar
Other Motorcycle Year: 2016
That may be irrelevant now, Paul - the spring inside LuxBlue's tensioner snapped, and I think he's decided this one is snake oil and gone back to the stock tensioner.
Old 7th January 2013
Paul's Avatar
Good to know...Thanks.
Old 11th January 2013
LuxBlue's Avatar
Yup, unfortunately, although not "snake oil", (it does work great when it works), the spring is a weak link that can't be trusted. (My opinion.)
At least one other member on here also developed a broken spring.
I only found mine when I tore down to rebuild my starter solenoid.
Old 26th March 2016
Metalbender1's Avatar
Metalbender1 Metalbender1 is offline
Metalbender1 is a jewel in the roughMetalbender1 is a jewel in the roughMetalbender1 is a jewel in the roughMetalbender1 is a jewel in the roughMetalbender1 is a jewel in the roughMetalbender1 is a jewel in the roughMetalbender1 is a jewel in the roughMetalbender1 is a jewel in the roughMetalbender1 is a jewel in the roughMetalbender1 is a jewel in the roughMetalbender1 is a jewel in the rough
Thanks for the write up LB.
