0 Cases Full Of Oil
0 New users of Windows 10
Last Post: awesomeduror
0 Sprocket cover with chainsikle rearsets?
Last Post: Jason's Sporty
0 On starting a new thread
0 Loose oil pump feed fitting - 2019 Iron
0 Powerraythor conversion
0 RSD Rear-Sets for '04-'13 Sportsters
Last Post: kobra50
3 Shaky Dave Recovery
0 Deer hunting at stairman's.
Last Post: Bow only
0 Speed
0 gas cap
0 Buy A new battery
Last Post: denguy
5 What year is the most collectible Sportster.
Last Post: denguy
14 TC 88A Chat
0 sportster and a grand
gp9739 (75), danbango (72), andyman1958 (61), 55 Jr (58), Love2FixIt (50), keywan (48), C Dubya (45), CA71xlch (44)
Old 15th February 2008
biknut's Avatar
biknut biknut is offline
Sportster/Buell Year: 1988
Default Once you go Thunder Monster you never go back
At least that's what I hope. My Hooker Step Tuned Drag Pipes work great, but they're too quite. When I first bought them they came without baffles. I rode around like that for a couple weeks. Sound level was about right, not too loud, just about right. There was a problem though. The mid range was weak, so I ordered a set of Hooker 3/4" baffles that Hooker recommended and wala, problem solved. Except for one thing. TOO QUITE. They work great but they're too quite. I think the main reason these pipes don't tend to be very loud is the first 6 " of header coming from the port is only 1 1/2" dia.
So hopefully Thunder Monster to the rescue. What I hope is louder with no loss to the mid range.
Who's got Thunder Monsters, and how do you like them?
FYI the pipe I had before was a Thunder Header.
Roadster_Rider's Avatar
Roadster_Rider Roadster_Rider is offline
Other Motorcycle Model: Victory High-Ball
Roadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura aboutRoadster_Rider has a spectacular aura about
I hope they're not too QUIET for you. Don't forget to give us a review when they arrive.
Cory
NoTrace34's Avatar
NoTrace34 NoTrace34 is offline
NoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura aboutNoTrace34 has a spectacular aura about
I love mine! Put them in a cheap set of Cycle Shack drags and the difference is amazing!
The other white meat.
khaskins's Avatar
khaskins khaskins is offline
Other Motorcycle Year: 1970
I've been looking at those for a while. I might just pick a set up for my sideshots.
2006 883L
AN Big Sucker Stage 1
Vance & Hines Side Shots
Joker Machine Speedo Mount
Speedway Instrument MicroTach
Mid Controls
Progressive Fork Springs
Knock-off SE Fork Brace
Chopped Rear Fender
Custom Taillight
Outlaw Name Generator
GrumpyCoyote's Avatar
GrumpyCoyote GrumpyCoyote is offline
GrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura aboutGrumpyCoyote has a spectacular aura about
Wait - louder but with no performance impact? Do you drink decaf coffee too?
Like tits on a boar, no reason for it in my opinion. If you are not making it better, why bother?
My guess is these things will sound like crap - all bark, no tone. Let us know how it works out though.
"The final measure of any rider's skill is the inverse ratio of his preferred Traveling Speed to the number of bad scars on his body. It is that simple: If you ride fast and crash, you are a bad rider. And if you are a bad rider, you should not ride motorcycles."
- Hunter S. Thompson, Song of The Sausage Creature
" First, a word on motorcycle safety: If you've put yourself in a position where someone has to see (or hear) you in order for you to be safe -- to see (or hear) you, and to give a **** -- you've already blown it."
- Neal Stephenson, 'Zodiac' (parentheticals are mine)
HDandME's Avatar
HDandME HDandME is offline
HDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enoughHDandME will become famous soon enough
Educate yourself before bashing. These are the best sounding baffles I have heard. ALOT of R&D has gone into the design of these baffles. They absolutely are not just a pipe with a washer welded on a stick.
http://www.bigcitythunder.com
Biknut, I have a set of these in my SEII's. I absolutley love the sound they present. Trust me, they are not quiet. They are not overly loud when cruising, but you open it up and holy sh!t they will bark. They have a nice deep rumble with none of that tinny/raspy sound alot of pipes present. There are a few threads on here about them. You'll love them!
If you run into any issues instaling them or have questions give them a call. I talked with the owner when I was installing mine due to a slight alignment issue. He was very willing to help and a stand up guy.
Masshole Rider.
01 1200C.
SEII slip-ons, Big City Thunder baffles
Forcewinder XR, NGK Iridiums
Amsoil 20W-50 all holes
"Roll with the mystery, life is uncertain." -- Indian Larry
rfranz1952's Avatar
rfranz1952 rfranz1952 is offline
Sportster/Buell Model #2: XLX
Sportster/Buell Year #2: 1985
Other Motorcycle Model: Yamaha Vino 125
rfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nicerfranz1952 is just really nice
Ive got them in me SE II's, and they are great. Idling about the same--maybe a little louder than the stock SEII baffles. Open the throttle, and wow!!!.
They have an extremely nice sound when cruising at 3,000 to 4,000 rpm.
2005 XL 1200 Custom; NRHS 1250 Conversion, 10.5 - 1; Stage 2 Heads; SE 536 Cams; Jim's Hydrosolid lifters; NRHS adjustable pushrods; S&S Roller Rockers; Crankshaft by Darkhorse Crankworks; HurricaneFlow A/F; Hurricane Oil Filter; Mikuni HSR-42; S&S Intelligent Spark Technology Ignition; RB Racing LSR exhaust; Front and Rear Progressive Suspension; Oversize front tire; Superbrace Fork Brace; Speedway Microtach, lots of other bits and pieces.
THE $16,000 Sportster!
dave76's Avatar
dave76 dave76 is offline
Senior Master Bike Builder
Sportster/Buell Model: Sportster XLH 1200
Sportster/Buell Year: 1990
Sportster/Buell Model #2: Sportster XLH 1000
Sportster/Buell Year #2: 1976
dave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to beholddave76 is a splendid one to behold
I got a set for my brand new Vance & Hines Straightshots on recommendation from a friend. When the wether finaly breaks I'll put the system on my bike and chuck the 1 3/4 cheap drags. lol
1990 1200 Sportster, Cycle Shack drag pipes, XLC forward controls, Zippers Billet 4 speed trap door.Update, 86 1100 heads, NRHS 1250 cylinders, Andrews V4 cams, and Compufire Elite 1 ignition. 07 Buell oil pump, Complete Andrews 4 Speed gears and shafts, Barnett Scorpion clutch. HHI 3' mid glide trees. HHI 6 piston front caliper, H-D floating rotor.
Easy there Sport... I'm not bashing anything (re-read the part where I said "my guess...") - I've just seen too many BS products with totally un-backed claims. Sound is subjective. You may think they sound awesome but I would likely disagree - louder is rarely better in my experience.
As for the product, snake oil is snake oil no matter how you package it. This one looks like a scam to me (especially after reading the site). Perhaps I'm just a jaded old bastard, but if I had a nickel for every dohicky like this I've seen over the years, I could buy the MoCo. If I had a nickel for every one that actually worked, I wouldn't have enough for a cup of joe. Odds are against it.
Funny, cause thats exactly what they look like to me.
If it works, awesome, but the jury is out as far as I'm concerned.
biknut's Avatar
What a struggle that was. Cussing, hammering, beating. It took almost 10 minutes and got my hands dirty.
