0 Hello from new member Chuck
0 2014 883 Question
0 Smacked a deer last night
0 Sportster engine wt.
Last Post: Screw Loose Dan
0 Howdy
0 Why Torx?
0 Accelerator nozzle and idle not right
Last Post: sportyone
0 Cycle Electric 5000 initial charge time?
Last Post: Yellowstone Kelly
0 Does this price seem right? $9500 '74 Ironhead
Last Post: MnKevin
0 Turbocharged carbureted sportster
Last Post: Racepres
0 Runs great - stalls on clutch pull
Last Post: tedcool
0 EFI Sporty Hanging Revs
Last Post: gwd1994
0 WTF Happened
0 Fat boy wheel
Last Post: Uberstorm
0 Uk rider first ironhead ownership
0 Hello
5 Clear all oil and debris in system ?
Last Post: groovemeisterus
0 Grips/bars pinching wires
Last Post: awright2009
Last Post: DirtyCory
0 Rivera contact for parts?
Zanzibar, stvmike (66), Leroywulf (62), Erik (59), SoCal Harley (54), drew96 (42), Reverend_d (40)
Old 8th October 2013
wedge's Avatar
wedge wedge is offline
Why dont the fat outer race face out ?
http://www.skf.com/binary/12-97838/519961-.pdf
Re-read my post, it does. The fat INNER race points in. The fat outer race points out (or at you like I said).
rocketmangb's Avatar
Guess i read it wrong thats why it made no sense to me
Bearing goes in the BACK of the housing fat out outer first.
Check !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
ReddTigger's Avatar
Right the fat outer race goes first......
Because the retainer needs to go in w with the bearing on the inside
States I've Ridden in
71.3 hp 70.8 tq
mikeLI_77's Avatar
@Tigger: If I remember correctly that is the same thing that happened to me on the way home from what I think was the philly cheese steak run wear we got stuck on the Staten Island Expressway on the way home for 2+ hours and I also slightly burnt up my clutch from it not disengaging correctly the whole time.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
wedge's Avatar
This can easily get confusing because we are now talking about the bearing holder that is held in with the big retaining ring. The bearing goes into that holder with the fat outer race going in first, and the threaded adjuster goes in with the mushroom end on that back side where you push the bearing into. There is also a small clip that holds the adjuster into the center of the bearing. One of those gets pressed, and I can't remember if you press the adjuster screw into the bearing center race, or if you press the bearing into the holder. One is press fit, the other just slides in, and I suspect the clip on the adjuster means it is the one that is a slip fit.
Just remember that as you pull on the adjuster screw you want to be pulling the fat side of the inner race into the bearing towards the fat outer race so that the balls are running on the thicker material of both races when under pressure so they don't wear out quickly in the pattern you see in the failed bearing pictures.
geoff's Avatar
geoff geoff is offline
Sportster/Buell Model: XL1200 Low
Sportster/Buell Model #2: XLH1200 - Dearly missed
Sportster/Buell Year #2: 1994
geoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond reputegeoff has a reputation beyond repute
Bearing is pressed into the plate, the adjuster screw slips in and is held by a clip
My life isn't completely about my Sportster. However, my Sportster makes my life complete.
~Grind~ ~Grind~ is offline
Sportster/Buell Year: 04
~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute~Grind~ has a reputation beyond repute
Originally Posted by Ocgreenmachine View Post
Grind, any particular brand on the 7200B angular contact bearings? Also, size is 10x30, correct?
Sent from my iPhone using Tapatalk - now Free
I don't know the manufacturer of the bearings I purchased. Yes the size is 10x30x9. The package had ASIN:B002BILZC along with the 7200B 10x30x9 Angular Contact printed on it.
Here is how Dirty Don explained the installation process.
Originally Posted by Dirty Don View Post
I went out and looked at mine, all apart, and it looks like the primary cover might need to come off, maybe not. But the throw out bearing is in its own little housing, held in by a retaining ring and the assembly can be removed. Then you take the small retaining ring off the threaded shaft and press it out. The bearing itself can then be pressed out of its housing, press the new one in, by the outer race, making sure the widest side of the outer race on an angular contact bearing goes into the housing first, then replace the shaft and retaining ring, put the assembly back in with its retaining ring and it's done. You must be sure of the orientation on an angular contact bearing so your thrust is applied to the races properly. Then put your primary cover and the rest back together.
Sounds right Grind
If ya put it in the other way it wont live for shit !
ReddTigger's Avatar
It will probably live longer then oem.I ordered then today,.should have then next week
