0 Newbie
Last Post: randy3934
Last Post: wongjohnson
0 OEM Headlight Bucket?
0 Chris Farley Bike
0 Mid Control?!
Last Post: MikeBel
Last Post: leon bee
0 MS rollers way too tight
0 carbs?
0 Happy Thanksgiving
Last Post: bklyngeezer
0 Grateful Dead Timing Cover Source?
0 Halloween 1250 Conversion
0 Better Brakes
0 Northern Canada late 1950’s
0 Oil leaks
0 oil bag
4 1995 S2 buell
Last Post: J!nx
0 Spacer swingarm bearing
Last Post: eddie XLX
0 81 parts
Last Post: Andy Hog
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: Desertfox
0 XLCR replica in progress
Last Post: rg500
Last Post: XL1275
excel50 (79), blazer95 (70), mycle1000, Barryn37 (59), QBALL (59), paulieb (58), cfranz (47), BMXATV (46), ravyn3 (41), Texas_Wild, hillpope (38)
View Poll Results: Stock Spring plate, has it gone bad on you
Solid Mount- (2003 and earlier) Still Good (below 50k) 61 20.75%
Rubber Mount (2004+)- Still Good (below 50k) 103 35.03%
YES -Solid Mount 10,000-20,000 5 1.70%
YES -Solid Mount 20,000-30,000 3 1.02%
YES -Solid Mount 30,000-40,000 6 2.04%
YES -Solid Mount 40,000-50,000 3 1.02%
YES -Solid Mount 50,000 + 3 1.02%
YES -Rubber Mount 10,000-20,000 26 8.84%
YES -Rubber Mount 20,000-30,000 29 9.86%
YES -Rubber Mount 30,000-40,000 11 3.74%
YES -Rubber Mount 40,000-50,000 4 1.36%
YES -Rubber Mount 50,000+ 5 1.70%
No Solid Mount 50,000+ 19 6.46%
No Rubber Mount 50,000+ 16 5.44%
Voters: 294. You may not vote on this poll
Old 4th November 2013
ReddTigger's Avatar
Default Clutch Spring plate poll
So with all the talk lately about people having the spring plate go ka-boom. I figured it was about time to determine who, what, when, where they go bad..
so,, please vote and don't be afraid to quantify the poll with a description..
States I've Ridden in
71.3 hp 70.8 tq
ReddTigger's Avatar
Replaced my clutch pack at 70k, spring plate was still good..
ParrotHead's Avatar
Other Motorcycle Year: 1974
Replaced my spring plate at 68K on my rubber mount. It was way bad ...
Got rid of it all together at 102K, anyone want it?
John Wayne - "The Shootist"
[URL="https://chrisridingadventures.wordpress.com/"]Check out my Blog[/URL] for my trip reports:
[URL="https://www.buzzsprout.com/129999/841095-episode-170-interview-with-chris-comly-of-chris-riding-adventures-blog"]Click here [/URL]to listen to my interview about my Sporty and riding on the Motorcycle Men Podcast
[URL="https://www.buzzsprout.com/129999/2188085-episode-221-interview-with-iron-butt-rally-veteran-chris-comly?fbclid=IwAR2AuBjIEvI8AoLtC7ZCZ4VC5Er_Guo8WfaRjh-15tRD9a5_rLYlp_jdJBg"]Click here [/URL]to listen to my interview about the Iron Butt Rally on the Motorcycle Men Podcast
[URL="https://horizon.bmwmoa.org/episode-93-chris-comly/"]
Click here[/URL] to listen to my interview on the Chasing the Horizon Podcast
[URL="http://sportsterpedia.com/doku.php/start"]Click here for the Sportsterpedia![/URL] for technical information & advice
Gcram399's Avatar
Gcram399 Gcram399 is offline
97 framemount, 11,000 miles. Springplate and clutches still like new but removed them when I installed my Energy One clutch pack to keep up with my performance upgrades.
Better safe than sorry.
George
--Thomas Jefferson
decman decman is offline
Post no Avatars!
Sportster/Buell Year #2: 1988
Other Motorcycle Model: FXDXT
OK, my 2003 50k + miles looked like new.
Just did a friends 1985 evo BT with 70k again like new.
No burn outs, wheelies or any other crap on these.
cHarley04's Avatar
cHarley04 cHarley04 is offline
Sportster/Buell Model: XL1200C/1250
Sportster/Buell Year: 04
cHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant futurecHarley04 has a brilliant future
I proactively replaced mine at 50,000. When it was removed it was still intact, but the brass rivets were getting real sloppy.
IMO, the lifespan of the spring plate has a lot to due with clutch usage and not so much with mileage. I happen to do a lot of rural road and slab cruising which accounts for my getting 50,000+ miles from it. If most of my mileage had been in town stop and go, I probably would not have seen that kind of life from the spring plate.
My guess is that the typical, around town Sporty rider, will likely have problems closer to 25,000 miles.
Hammer 1250-Smash Heads-560 Cams -Hurricane Flow AC -Supertrapp Supermeg -TC88A
Mine on the '06"R" really started acting up as we were running through downtown Astabulah on one of the Lake Erie loops a couple of years back. 90 degree heat, stop and go traffic and I couldn't stop the creeping, or find neutral and wasn't sure what the hell was going on. It wasn't a widespread, well known issue back then, guess I might have been on the leading edge.
I.B.A.#26543,
Sportster/Buell Model: XLH 883/1250
Sportster/Buell Year: 1991
Kind of confusing poll, but it looks like only solid mounts have no problems and rubber mounts have all of them. Of course, these are early polling results.
I'm with the solid mount crew, ignorance is bliss for me. So far.
John
Old 5th November 2013
ReddTigger's Avatar
John
I can recall no known spring plate issues prior to rubbermounts. But figured this would Help to visualize the results. And who knows, I may get surprised.
sprink's Avatar
sprink sprink is offline
Sportster/Buell Model: 2004 XL1200R
Sportster/Buell Year: SOLD
Sportster/Buell Model #2: 2000 X-1 lightning
Sportster/Buell Year #2: SOLD
Other Motorcycle Model: XB1200XT "Uly"
Other Motorcycle Year: 2009
sprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond reputesprink has a reputation beyond repute
I opened my 2004 after 41,000 and my plate looks fine. The frictions on either side were worn more than the other frictions. Stack measured .684, .661 is worn out... not sure what they start at....
