0 Speed
0 1200 conversion
0 Not an ironhead, but....
Last Post: Peteroo
Last Post: t120r
0 On starting a new thread
0 Cometic Valve Stem Seal Install?
Last Post: BlackBikeDave
0 Will 04 and later used jugs & pistons fit 01 without major problems?
Last Post: tussuck
Last Post: Skeezix
0 5 gal tank
Last Post: Magneto Sportster
0 opinion time (bike broke again)
Last Post: Skeezix
0 testing wiring harness connections
0 2011 1200C tuner?
Last Post: tussuck
0 Timing
Last Post: ezmerf
View Poll Results: Stock Spring plate, has it gone bad on you
Solid Mount- (2003 and earlier) Still Good (below 50k) 58 20.42%
Rubber Mount (2004+)- Still Good (below 50k) 97 34.15%
YES -Solid Mount 10,000-20,000 5 1.76%
YES -Solid Mount 20,000-30,000 3 1.06%
YES -Solid Mount 30,000-40,000 6 2.11%
YES -Solid Mount 40,000-50,000 3 1.06%
YES -Solid Mount 50,000 + 3 1.06%
YES -Rubber Mount 10,000-20,000 25 8.80%
YES -Rubber Mount 20,000-30,000 29 10.21%
YES -Rubber Mount 30,000-40,000 11 3.87%
YES -Rubber Mount 40,000-50,000 4 1.41%
YES -Rubber Mount 50,000+ 5 1.76%
No Solid Mount 50,000+ 19 6.69%
No Rubber Mount 50,000+ 16 5.63%
Voters: 284. You may not vote on this poll
  #311
Old 8th September 2019
Originally Posted by boomerguy View Post
So far, my 2005 with 14K miles on it feels like all is well but I'm a proactive type of guy. I've gathered all the parts, video's and pictures so I could make my own list of instructions for a relaxed therapy project in the man-cave. This will be saved for one of those fall weeks when it is just too miserable to go outside but the man-cave/garage is still warm enough that my fingers haven't lost their feeling. I'm going to replace the grenade with 2 steels and one friction to make everything stock, and I'll replace the stock throw out bearing with a 7200B bearing at the same time. I'll post the results then.
I found the time on some cool mornings last week to replace the throw out bearing and the grenade plate. I posted the details of tools, steps and results in a separate post. I hope this helps some DIY riders. It is not a hard job if you take your time, plan well and have the right tools. If I could do it, anyone can.
UPDATE:
Nearly 2000 miles later, the new throw-out bearing and grenade plate removal continues to make rides more enjoyable than ever. I ride mountain twisties all the time it seems I shift every few seconds throughout all of my rides. The smoother and easier clutch pull (to me, anyway) and slightly quicker clutch engagement are far better than what I had before, which weren't that bad in the first place and the parts I removed were still in very good shape. So I figure went from "good" to "better". I encourage everybody to do this. It's not expensive, not hard to do and the only special tool I needed was the clutch spring remover.
