0 .551 Cams in an EFI 1200
0 1993 XLH883 Ignition switch Wiring
0 Multiple timing marks?
0 Handlebars
0 Riding in the rain
Last Post: seajay
0 Removing countershaft from access cover
Last Post: Russ
0 Anti reversion “muffler”
Last Post: JaKaL
Last Post: a-sad-anorak
0 question about new trans door
0 Where were the IronHead sportsters Made.
0 BMW reverse trike build
vlmuke, wazza (48), Grizzwold (44), roaldtm (39), redtacoma31 (34)
View Poll Results: What would you use on your sporty for performance?
Mikuni HSR42 82 71.93%
S&S Super E 32 28.07%
Voters: 114. You may not vote on this poll
Old 14th November 2014
maru's Avatar
maru maru is offline
Sportster/Buell Year #2: 1996
maru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud ofmaru has much to be proud of
race only purpose built bike.. S&S
anything else.. Mikuni
I agree.
Old 19th December 2014
pcontiman's Avatar
pcontiman pcontiman is offline
pcontiman has disabled reputation
Nice bike Jester, well done.
www.bible-research.org
Old 22nd December 2014
how about a lake slider carb!?! no float bowl to mess up things.
Old 29th January 2015
maru's Avatar
The problem with super simple carbs is that while it may be simple to make them richer or leaner, it is impossible to get them to meter correctly at the full range of operating conditions a street bike is faced with.
An S&S works best when a thunder jet is added and bleeds are manipulated in order to give it an effective additional metering circuit. Simple is nice, but only if it works as good as not so simple.
The Lectron, EI, lake injector, etc. all can work great at Wfo. They are all to crude to be close to ideal in a street application.
Simple carbs appeal most to folks that are afraid to get lost in the shuffle of tuning a multi circuit carb. That task is not rocket science and almost anyone can learn to tune carbs. It is a matter of understanding what does what and why and then developing the experience to read your progress as changes are made.
Honestly almost any carb can be made to work, to some degree. Some are better for certain applications, for sure.
stretch7's Avatar
stretch7 stretch7 is offline
Sportster/Buell Model: XLC 883-90"
Sportster/Buell Model #2: M2 Cyclone
Sportster/Buell Year #2: 2002
Other Motorcycle Model: Buell Blast
Other Motorcycle Year: 2002
stretch7 is a name known to allstretch7 is a name known to allstretch7 is a name known to allstretch7 is a name known to allstretch7 is a name known to allstretch7 is a name known to allstretch7 is a name known to allstretch7 is a name known to allstretch7 is a name known to allstretch7 is a name known to allstretch7 is a name known to all
I'd love to try an S&S on mine but I can live with the HSR.....
XL883C- 90" NRHS, XB heads, .536 cams, HSR 42, NRHS 3" Hurricaneflow airfilter, Supertrapp 2-1 (24 plates), BDL heavy duty clutch, Andrews 1st gear, 12.5" FAR adjustable shocks, Oberon eng. footrests, flush filler cap, JMC swingarm, GSXR upside down front end, etc, etc, etc.......
And a Buell M2.......To help use up the worlds rubber resources....
Old 3rd February 2015
you are correct on the lake slider as it best performs on a track. however, they can be made streetable. like any carb, trial and error. the gravity flow is largely controlled by the tapered needle but for the average joe you are probably right, overly complicated even though simple as can be.
Old 8th February 2015
Bob F's Avatar
Bob F Bob F is offline
XLF LIFEMEMBER Im retired
Lectron?
+2 Had one on my 1982 FXR and loved it. It was Harleys performance carb back then.
http://www.lectronfuelsystems.com/
Old 29th March 2015
norseXL's Avatar
norseXL norseXL is online now
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1994
If you by racing mean drag racing, then yes.
As for real racing, with bends, a flat-slide is the only way.
...and I have a 45 HSR and a matching Hammer manifold on the shelf to put on.
Tore
"In the design of an internal-combustion engine, as in all creative work of this nature, the æsthetic side must not be overlooked.
In the first place, beauty of form and of proportions is in it self an admirable guide to mechanical correctness;
for mankind has come to regard as beautiful that which is mechanically correct, whether it be in nature, in architecture, or in enginering."
Sir Harry R. Ricardo
Old 14th May 2015
AnaChris's Avatar
AnaChris AnaChris is offline
Sportster/Buell Model: 883xlc/1250
Other Motorcycle Model: FLHRCI
AnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant futureAnaChris has a brilliant future
real racing?....waddya mean "you people"?
2004 883C/1250, 30degree reverse dome 10.5:1, matching crushed XB1200 heads ported w/oversized valves, S&S roller rockers, Hammer .600 cams, billit intake, hsr42, TC88, innovative afr, bronze oil gear, alto carbonite clutch, patriot defender, all balls starter, 1 1/2 tank lift, f6 key relocation,steering damper
Old 14th May 2015
Bob s hog's Avatar
Bob s hog Bob s hog is offline
Sportster/Buell Model #2: 1200 xl sportster custom
Sportster/Buell Year #2: 03
Other Motorcycle Model: 1200 low sportster
Other Motorcycle Year: 06
Bob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to beholdBob s hog is a splendid one to behold
both carbs are great as is any carb in the right hands. if not jetted right they all can be a pos.
