0 Better Brakes
0 just for my head
Last Post: 93trident
0 Grateful Dead Timing Cover Source?
0 Brake light issues
Last Post: 45Brit
Last Post: david.hanaga
0 MS rollers way too tight
0 Newbie
Last Post: BitterOldMan
0 Oil leaks
0 Mid Control?!
Last Post: denguy
0 Holiday Sale At Hammer Performance
Last Post: Turbo Sporty 48
0 Forward controls on a 2 into 1 exhaust system.
Last Post: exexpat93
0 OEM Headlight Bucket?
0 Chris Farley Bike
Last Post: wongjohnson
Last Post: leon bee
0 carbs?
0 Happy Thanksgiving
Last Post: bklyngeezer
0 Halloween 1250 Conversion
0 Northern Canada late 1950’s
excel50 (79), blazer95 (70), mycle1000, Barryn37 (59), QBALL (59), paulieb (58), cfranz (47), BMXATV (46), ravyn3 (41), Texas_Wild, hillpope (38)
Old 26th January 2017
ParrotHead's Avatar
Other Motorcycle Year: 1974
I have found the clutch adjustment is a little more sensitive without the springplate but otherwise no real change.
I have a clutch I removed with approximately 30-40,000 miles on it and the steel and fiber plates look fine (Most of my miles are highway). PM me an address and I will drop them in the mail.
John Wayne - "The Shootist"
[URL="https://chrisridingadventures.wordpress.com/"]Check out my Blog[/URL] for my trip reports:
[URL="https://www.buzzsprout.com/129999/841095-episode-170-interview-with-chris-comly-of-chris-riding-adventures-blog"]Click here [/URL]to listen to my interview about my Sporty and riding on the Motorcycle Men Podcast
[URL="https://www.buzzsprout.com/129999/2188085-episode-221-interview-with-iron-butt-rally-veteran-chris-comly?fbclid=IwAR2AuBjIEvI8AoLtC7ZCZ4VC5Er_Guo8WfaRjh-15tRD9a5_rLYlp_jdJBg"]Click here [/URL]to listen to my interview about the Iron Butt Rally on the Motorcycle Men Podcast
[URL="https://horizon.bmwmoa.org/episode-93-chris-comly/"]
Click here[/URL] to listen to my interview on the Chasing the Horizon Podcast
[URL="http://sportsterpedia.com/doku.php/start"]Click here for the Sportsterpedia![/URL] for technical information & advice
Old 27th August 2019
I just discovered this thread about upgrading the clutch with stock parts instead of performance parts. It looks like a no-brainer for those of us who just like to tour/cruise and don't have the extra dollars to spend.
Are there any updates on the pro's and con's of doing this?
Nibelungen's Avatar
Sportster/Buell Model: xl883n Iron (2019 engine)
get rid of the brass rivets spring plate...
install what else you like... SE, Barnett, Alto, whatever...
it's a shame, IMO, they still came equipped like this
if they would at any cost a cushion effect why not a compensator on the rear sprocket like the Japanese market Sporties...??? or a system like that on XRs...???
on the lion's corpse celebrate the dogs... still the dogs are dogs and the lion a lion...
60Gunner's Avatar
60Gunner 60Gunner is offline
Anyone that needs some good used stock friction discs and plates, give me a holler. I have a whole stack of them.
Old 28th August 2019
I'm going ahead to change my grenade ring for stock rings (2 steel, 1 friction). As far as I know, there is no damage to anything but I am closing in on the 15K mile warning zone. While I'm doing this job, is there any other part I should check or replace, such as a bearing? I'm new to motorcycle transmissions but I know what a clutch release/throw-out bearing is in a car's manual transmission and it is a sacrificial bearing that always should be replaced.
Here's the Sporsterpedia section on the Clutch:
http://sportsterpedia.com/doku.php/t...vo:priclutch01
It's worth a good read to understand how the clutch works and How & Why to make the clutch adjustment...
Bone's Avatar
Bone Bone is offline
Sportster/Buell Model: FLHP
Sportster/Buell Year: 2016
Sportster/Buell Model #2: Guzzi V7 Stone
Sportster/Buell Year #2: 2013
Other Motorcycle Model: 18 Guzzi V7D / 11 Duc 696
Not for nothing. But if I were doing it again I would definitely go with the XR1200 judder spring instead.
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
...While I'm doing this job, is there any other part I should check or replace, such as a bearing?...
Yes, replace the clutch release bearing. Put in the 7200B angular contact bearing Harley should have used originally. It's a "replace it before it fails" thing like preemptively replacing the grenade plate.
If you get the dreaded clutch squeal/shudder add Redline Limited Slip Additive an ounce at a time 'til it quits.
https://www.amazon.com/gp/product/B0...AN9A0OWP&psc=1
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: XL1200CX Roadster
Sportster/Buell Year #2: 2017
b0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond repute
Remove !!!!!!
Old 29th August 2019
Wow! I sure am glad I asked that question! That info should automatically be associated with the grenade ring. I'm ordering the 7200B right away. This is one of those "while I'm at it" moments that I actually did something right, the first time.
Thanks, everybody.
