0 Wanted
Last Post: maltesefalcon
Last Post: 1200CustomHD
0 Hello from Home of HD
0 Hurricanes
0 2013 48 what would you update first?
Last Post: Clevspeed
Last Post: Whitewalls
0 What Marker Lights Are These?
Last Post: seajay
0 KR style bolt on hard tail for 78 XLCH
Last Post: DirtyHarry68
Last Post: Diogenes415
0 13" Harley Take Off Air Shocks - $90
Last Post: mrbreezeet1
0 Progressive Suspension 412-4055C Chrome, 13" Heavy Duty springs, Rear
0 Carb fastening screw size?
Last Post: Snowplow
0 Ideal RPM
0 Which Battery?
Last Post: Hellbent_4
0 Sportster 1200S piggyback rear shocks for sale
Last Post: vferdman
6 ironhead turn signals
Last Post: BigMek
0 Swapping out single speedo for 1200 dual gauge setup
Last Post: beau-kat
0 Cobra NH slipons
Last Post: guncrank
0 Rubber Mount Seat for sale
Last Post: vferdman
DaddyJay, sixshooter (73), cartoad2001 (71), Dirty Ernie (65), ncpickman (59), bri1200c (57), pquirk (54), GOTWA (51), gremlinsteve (51), lbowles2 (49), Guess (41), rnaway22es, landon283 (32)
bretaher, head, leak, oil
Old 3rd July 2018
davy davy is offline
Sportster/Buell Model: Sportster XL1200 CUSTOM
davy is an unknown quantity at this point
Default Head breather and Oil leak
Hi,
I bought the SS Teardrop air cleaner for my 98 sportser xl1200. The bike is running great with it. However, I noticed the head and base gasket started leaking.
Could it be possible that head breather assembly (banjo and rubber) is more restrictive than stock and causing that problem ?
Time to change all those gaskets... ?
The bike as 70 000km.
Thanks so much
Old 4th July 2018
JacksBrother's Avatar
JacksBrother JacksBrother is offline
Sportster/Buell Model: XL1200
Other Motorcycle Model: Harley Davidson FLH
Other Motorcycle Year: 1973
JacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud ofJacksBrother has much to be proud of
Originally Posted by davy View Post
Hi,
Thanks so much
Welcome to the Forum!
I'm running the same set-uo on my '98 1200 as well. I like it a lot. Which cylinder is leaking?
I seriously doubt that the breather hose / banjo bolt system could have any affect on your gasket leaks. I think that the 50,000 miles on the speedometer is a more likely culprit.
Good luck with your gasket change,
Joe
Old 5th July 2018
sportysrock's Avatar
Sportster/Buell Year: '96
Sportster/Buell Year #2: '72
The vent hole in a stock breather bolt is about 1/16". Did you notice how large the S&S are?
Sent with :-)
Old 24th September 2019
kneeco's Avatar
kneeco kneeco is offline
Sportster/Buell Model: Sportstser XLH
kneeco is an unknown quantity at this point
I had same issue with a breather kit. The opening were similar size but the angle the banjo bolt creates and the longer run disrupted the airflow enough to upset my bike.
60Gunner's Avatar
60Gunner 60Gunner is online now
Your umbrellas may be shot too and you're sucking air in. Pressure will build.
Vent from the cam chest and your gasket leaks will be but a distant memory. Better ring seal too.
No more mess dangling from your heads or air cleaner. No more oil all over the side of your motor.
Plug them with solid bolts and never look back.
Check out "Installing the Ultimate Crankcase Vent" in the Sportsterpedia.
I use the Hayden Krankvent KVP38.
http://sportsterpedia.com/doku.php/t...ref:engmech05d
Hippysmack's Avatar
Yes, any changes to the OEM breathing system Can affect overall breathing in general.
How much, good or bad, depends on your individual engine variables.
If you run the line up or down from the head outlet, length and height of hose.
The first things you should look at if you're having problems is the umbrella valves.
They are flimsy rubber valves and they don't last forever.
If you run a filter on the end of the breather hose, take it off. It is unnecessary and in some cases very harmful to the breathing system.
It'll cake up with condensation / oil and hinder or stop up your breathing path.
The next thing to do is perform a compression or leakdown test to check if you have excess ring or valve leakage causing more air intake into the crankcase.
60Gunner's Avatar
Alternatively, and meeting Hippy in the middle so to speak, is add the krankvent in your breather hose after they come together. Keep it pointed down, run it under the frame, no filter like Hippy said.
This can be done if drilling/tapping a hole in the cam cover doesn't appeal to you. It's a better designed one way valve, it's external and comes apart for easy cleaning if it were necessary, and you won't have the stock umbrellas to worry about failing again and removing your rocker covers to fix. For best results they should be removed tho.
Cam chest venting is best tho imo. If for no other reason, aesthetics. Altho some of believe it's the best place to vent. A controversial subject with no definitive proof either way at best. Now you can make an informed decision that suits you.
Hippysmack's Avatar
Originally Posted by 60gunner View Post
alternatively, and meeting hippy in the middle so to speak, is add the krankvent in your breather hose after they come together. Keep it pointed down, run it under the frame, no filter like hippy said.
+1
Old 25th September 2019
cycowrencher's Avatar
cycowrencher cycowrencher is offline
Other Motorcycle Model: 1984 KX 125
cycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant futurecycowrencher has a brilliant future
My root cause for excessive blow by through the head breather was my rear cylinder compression rings had the gaps lined up. I had to replace cylinders and when new rings were installed in the correct x pattern ( top comp at upper left, bottom comp at lower right, top oil at upper right, and bottom oil at lower left) my issue magically disappeared. I think I replaced the umbrellas 6 or 7 times and it was always there...even when I installed the cam chest breather setup...
Sent from my LG-LS993 using Tapatalk
USN 1991-1995 VFA-81/ USS Saratoga, Iraq 1, Kosovo/ Bosnia Conflict
Hippysmack's Avatar
The rings are always moving around and sometimes they do all line up that way.
They will move away from being lined up also. They don't stay in one spot.
But when they are lined up that way, they could easily allow more air thru.
