0 my sunday driver...
Last Post: 84rzv500r
Last Post: dodgetrucken
0 mainshaft rollers size
0 MS rollers way too tight
0 What engine oil do you use?
0 Cam question
Last Post: Heff
0 Secondery Vin tag
0 81 parts
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
3 Wtb, Wts, Wtt, Wtg (Evos)
0 XR750 resurrecting
Last Post: mofosheee
Last Post: LenC
0 Bike Beast
Old 12th February 2019
Bluto Bluto is offline
Other Motorcycle Model: Norton 850 Commando
Other Motorcycle Year: 1973
Default Grenade plate fix with XR1200 parts...
I replaced my grenade plate with two steels and a friction plate, that worked but often caused a very annoying squeal when taking off in first gear, a common problem from what I've read.
Did some research and learned that the XR1200 (and Buell XB's) use an entirely different judder spring setup BUT use the same regular friction and steel plates as an XL. Ordered the XR parts as my dealer didn't have them.
Finally got the XR1200 parts today and they work great...the grenade plate is gone AND the clutch squeal (sounded a lot like a slipping auto belt) I gained when I replaced it with two steels and a friction plate, plus clutch takeup is smoother now too. Basically the first friction plate is replaced with the XR1200 items and the spring plate is replaced with two steels and a friction, only need to buy two steels as the original first friction plate is reused.
Could have gone with an aftermarket clutch however my bike is only Stage 1 and doesn't need it, some of them squeal too, plus some of the makers are persnickety about what lube is used...wanted a clutch that was happy with the standard HD recommended stuff.
The photo shows the XR1200 parts plus the two extra steel plates needed, total cost about $65. BTW the spring has to go in the right way, the FSM section for the XR1200 clutch has a diagram that details this.
Old 13th February 2019
BKB's Avatar
BKB BKB is offline
Thanks, Bluto. Good info.
You are welcome!
This site has been a great resource when doing work on my Sportster, glad I got a chance to contribute something in return that is hopefully useful to some.
Bluto - Thanks for testing out this combination as a possible solution to the XL Spring Plate failures...
I would like to see at least a few months of wear & tear on this arrangement before including it in the Sportsterpedia...
Please post up again on this thread when you have a few thousand miles on the fix...
It should be pointed out that the XR1200 Clutch Basket is not the same as used on the XL models - The XR version has Compensating Springs built into the base to help with the 'shock' of clutch engagement...
Associated Thread - http://xlforum.net/forums/showthread.php?t=2044017
XR Parts to Replace XL Spring Plate
37894-02 Judder Spring
37895-02 Judder Spring Seat
37897-02 Friction Clutch Plate - Narrow
Extra Steel Plates (2ea)
37913-90 Steel Clutch Plate
Check Out The Sportsterpedia
Old 3rd April 2019
b0fh's Avatar
b0fh b0fh is offline
Sportster/Buell Model: XL883R
Sportster/Buell Model #2: XL1200CX Roadster
Sportster/Buell Year #2: 2017
b0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond reputeb0fh has a reputation beyond repute
may be a stupid question, but if I already have the grenade ‘eliminated’ by adding 2 extra steels and 1 extra friction (all the rest is stock) all I need to buy is the judder spring and spring seat? and hopefully it will make the clutch more ‘soft’ to engage and eliminate the squeaalllll?
edit: answering my own question, guess not - looking at ronnies diagram the ‘new’ spring goes in first and that friction plate that sits on top of the spring is different.
interesting idea but not sure I like the idea of losing 1 friction disk to fit that second spring in (basically going back to being a stock clutch with the grenade replaced by the judder spring).
but interesting idea nonetheless - let us know how it works out after several k miles!
Old 3rd April 2019
The judder spring and seat don't fit on top of the narrow "B'" plate shown above, they fit inside of it...so in effect you gain 1/2 of a friction plate with this setup. Anyway, put about 1000 miles on it so far and am confident that I'll have a trouble free clutch for many miles.
You need the three XR1200 parts as shown above plus two steel plates to do this fix...
Old 26th April 2019
b0fh's Avatar
just double checking...
stock clutch is 6 steels + 1 spring plate + 8 friction plates
my current setup is 8 steels + 9 friction plates
yours would be 7 steels + judder spring parts (incl. narrow friction) + 7 regular friction plates, correct? not sure if I like the idea of dropping 1 1/2 friction plates... but I don't see any problems with the setup either!
cheers
Old 26th April 2019
cheers
No, that math is not correct. As I said the first friction plate is replaced with the XR1200 parts, then it is reused along with two new steel plates to replace the spring plate, so in the end you have 8 friction, 8 steel, plus the narrow XR1200 B plate.
FWIW the Buell XB and XR1200 use 7 f, 7 s, plus the B plate...diagram below.
Old 26th April 2019
b0fh's Avatar
that's why I asked, the diagram for XRs calls only for 7 of each - guess the XL basket is a bit bigger so you can fit in 8 of each. good to know, we end up with an even better clutch than the XRs
Old 26th April 2019
Davo_137's Avatar
Davo_137 Davo_137 is offline
Better than the XR? That depends on how you look at it, the XR has that spring setup, I guess you could call it a Cush drive, it soaks up shock loads that cause wear to the gearbox.
