0 Speed
0 sportster and a grand
Last Post: stikflote
Last Post: eskimo619
Last Post: Len PA
0 5 gal tank
Last Post: spoon
0 front drum bearing fit
0 Flame's New 1989
0 1200 conversion
0 Not an ironhead, but....
Last Post: t120r
0 On starting a new thread
Old 14th April 2019
rocketmangb's Avatar
Check the throttle cable bracket when you get to it
WOT can be hard to achieve !
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 14th April 2019
RAIDER0372 RAIDER0372 is offline
Sportster/Buell Model: NIGHTSTER
RAIDER0372 is an unknown quantity at this point
Yes. Please keep the photos coming. If you don't mind. Totally understand if you dont. Thanks again.
RIDE HARD.
GOD SPEED.
Old 14th April 2019
Bryan1976's Avatar
Bryan1976 Bryan1976 is offline
Sportster/Buell Model: 1275 Sportster
Other Motorcycle Model: Dyna Wide Glide
Other Motorcycle Year: 1998
Bryan1976 has a brilliant futureBryan1976 has a brilliant futureBryan1976 has a brilliant futureBryan1976 has a brilliant futureBryan1976 has a brilliant futureBryan1976 has a brilliant futureBryan1976 has a brilliant futureBryan1976 has a brilliant futureBryan1976 has a brilliant futureBryan1976 has a brilliant futureBryan1976 has a brilliant future
Checked it out it has part # 19 on it for big twins . I have Dyna throttle cables on the bike so I’m thinking I don’t need 19a on it. Am I right? I do have a 19a in my old parts box if needed.
Blue collar knuckle buster. Just because I broke it doesn't mean I cant fix it and smoke you in 1/4 mile
Old 14th April 2019
You might be ok then !
Old 14th April 2019
Bryan1976's Avatar
Default My 1250 to 1275 build
I’m not gaping my rings I had Hammer do that. Yesterday when looking for a bearing puller I came across this and was shocked. The tools my father in law kept surprise me all the time. I thought some of you old timers would appreciate this.
Old 14th April 2019
I did my own with a file in the vise !
Old 14th April 2019
I think I may have set mine a little tighter than Hammer would
Old 16th April 2019
Bryan1976's Avatar
So I didn’t have much time to work on the bike tonight. I installed the roller rockers and new rocker pins.
After installing them I found the front ones have very little clearance on the valve side of the rocker box. Do I need to add some clearance? Here is a picture. I have never had roller rockers before so I don’t know if this is ok. I couldn’t find anything in the shop manual.
Old 16th April 2019
NGOT8R NGOT8R is offline
Sportster/Buell Year: 2019
NGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to beholdNGOT8R is a splendid one to behold
What size roller rockers are those? I wonder if the best option would be to have a machine shop use a mill to remove the material from the valve area (for consistency), rather than doing it by hand?
Old 16th April 2019
Bryan1976's Avatar
I think I might be over thinking this. I took the rocker box and placed it on the head. The valves fully closed and the roller was not even close to the housing.
