0 XLCR replica in progress
0 What engine oil do you use?
Last Post: SLW210
0 Roadster - No Key Start
Last Post: SLW210
0 81 parts
Last Post: Andy Hog
0 my sunday driver...
0 Halloween 1250 Conversion
0 mainshaft rollers size
0 Top end rattle at 3000 rpm
0 Northern Canada late 1950’s
0 Cam question
Last Post: T. Clark
0 tappet/blocks fitment by year
0 MS rollers way too tight
0 Secondery Vin tag
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
0 Superlow bar dimensions?
  #31
Old 28th September 2019
Drop a note to Chris, our “Parrothead”, as he has a Softail in his stable.
I.B.A.#26543,
Tonyb65's Avatar
Tonyb65 Tonyb65 is offline
Sportster/Buell Model: XL 883 DLX Sportster
Tonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to allTonyb65 is a name known to all
Thanks Paul will do
Old 29th September 2019
Tonyb65's Avatar
Faster project moving right along. Received the dash, speedometer, ignition switch dash mount plate kit and hardware. This is a test fit of the base mount plate, speedometer and ignition switch. Without installation instructions thought I would do my best to figure out the basic stuff. So did a test fit of the components unfortunately the dash did not fit so I have to return it to J&P cycles
Die cast dash plate mount
Die cast dash plate mount, FL style speedometer and ignition switch
side view of assembly
Pulled back for an oblique angle
Last edited by Tonyb65; 29th September 2019 at 03:04.. Reason: add another angle photo
I think Flame_ also has a Softail and might be of some help.
Old 9th October 2019
Tonyb65's Avatar
Right tank set to where it needs to be for final assembly. Need to Fab the mount brackets and then onto fuel lines and wiring.
Old 13th October 2019
Tonyb65's Avatar
Got the final fabrication of the tank mounts finished and installed. Needs some touch up paint, then final tank assembly, ignition and light wiring, then fuel lines.
Old 14th October 2019
Tonyb65's Avatar
Got the mock up and fabrication completed. I mounted the tanks in place Today. I think this is going to look great when finished.
rokytnji's Avatar
rokytnji rokytnji is offline
Sportster/Buell Year #2: 1983
Other Motorcycle Year: 1990
Nice to see mock up helped out before final assembly .
Next will looking for cracks if any stress is applied on mounting tabs on tanks. Hopefully. Static drop in was easy peasy and loosey goosey. Instead of shoe hoe horned in.
ose rank tabs crack easy from vibration sometimes if mounted under tension on mounting point.
Traveled to
Old 15th October 2019
Tonyb65's Avatar
Everything went on nice and easy during mock up and pre final assembly didn't have to put any stress on any of the tabs. However I intend to include looking at the tabs and mounts during every pre trip inspection.
Old 5th January 2020
Tonyb65's Avatar
I am almost done with the Fatster project just some minor tweaks and put the battery and seat back on fill the tanks and then a test ride.
