0 Grateful Dead Timing Cover Source?
0 Oil leaks
0 Newbie
0 Spacer swingarm bearing
Last Post: eddie XLX
0 81 parts
Last Post: Andy Hog
0 Better Brakes
0 carbs?
0 Happy Thanksgiving
0 Halloween 1250 Conversion
0 oil bag
Last Post: 93trident
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: Desertfox
0 MS rollers way too tight
Last Post: forqueue
0 XLCR replica in progress
Last Post: rg500
Last Post: XL1275
0 Roadster Inverted Forks (again)
Last Post: felis
0 mainshaft rollers size
Last Post: saddlebagrail
0 Secondery Vin tag
0 2020 End of Year Report
0 50 years of wins, the XR750
0 New sportster in HD Research Survey
Last Post: Marsikus
0 Northern Canada late 1950’s
0 Sender Unit Part Number
0 Larger Roadster tank for 79-81 Sportster
Last Post: blk80bike
truckmen (63), Scooter Trash (58), K2RMX.ROB (56), cherokee jim (56), Milazzo (54), benny04hd (40), Foxman (40), jimpo42 (34), Chase1126 (29)
Old 25th August 2019
Heavy Heavy is offline
Heavy is a glorious beacon of lightHeavy is a glorious beacon of lightHeavy is a glorious beacon of lightHeavy is a glorious beacon of lightHeavy is a glorious beacon of lightHeavy is a glorious beacon of lightHeavy is a glorious beacon of lightHeavy is a glorious beacon of lightHeavy is a glorious beacon of lightHeavy is a glorious beacon of lightHeavy is a glorious beacon of light
Default Grenade plate
I went to put on my Barnett extra plate kit today and ended up peeling a piece off of the basket. I ordered a used basket on eBay. Not thrilled. But am glad I got the grenade plate out because I picked brass rivets out during disassembly.
https://ibb.co/mDMpw6n
https://ibb.co/pJNVbPs
https://ibb.co/g6wLscw
xlerate xlerate is offline
Other Motorcycle Model: Yamaha FZR1000
Other Motorcycle Year: 1988
xlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond reputexlerate has a reputation beyond repute
Default distance
What distance had your Sportster traveled before you upgraded the clutch?
2006 XL1200R in Yellow Pearl with wire wheel option; 30t trans sprocket; SE Heavy Breather a/c; SE II slip-ons; S&S IST ignition; 48 pilot, 185 main, CVP EZ-just mixture screw; HEL braided brake lines; Race Tech Gold Valves, Ohlins S36E shocks, Superbrace; Dart screen, Mustang Vintage Solo; JH570 cams installation underway.
Old 26th August 2019
It’s new to me this year but it has 28k on the odometer. I’m thinking it’s the original clutch.
That snap ring is held in place by the spring locking ring - It is critical to compress the diaphragm spring far enough to press the locking ring down out of the way BEFORE trying to remove that snap ring...
Be sure to read over the Sportsterpedia section on the Clutch:
http://sportsterpedia.com/doku.php/t...vo:priclutch01
Good Luck with the used basket...
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
I will jump on it to save my brothers....run my friends.
Old 27th August 2019
So the used basket and parts are supposed to be in Wednesday.
I do have and was using the spring compression tool during disassembly.
The used basket claims to come with new plates, I’ll just toss those out and install the Barnett and Barnett spring and clutch cable.
Hopefully between the two baskets and a mess of plates I can slap it all together this weekend and be mobile again.
