0 Blackstone HyperTek
0 Loose oil pump feed fitting - 2019 Iron
0 New users of Windows 10
5 What year is the most collectible Sportster.
Last Post: hhugger
0 Cases Full Of Oil
0 Sprocket cover with chainsikle rearsets?
Last Post: Jason's Sporty
0 On starting a new thread
0 Powerraythor conversion
0 RSD Rear-Sets for '04-'13 Sportsters
Last Post: kobra50
3 Shaky Dave Recovery
0 Deer hunting at stairman's.
Last Post: Bow only
0 Speed
0 gas cap
0 Buy A new battery
Last Post: denguy
14 TC 88A Chat
0 sportster and a grand
gp9739 (75), danbango (72), andyman1958 (61), 55 Jr (58), Love2FixIt (50), keywan (48), C Dubya (45), CA71xlch (44)
Old 8th September 2019
vtwinlynne's Avatar
vtwinlynne vtwinlynne is offline
Sportster/Buell Model: Ironhead XLH
vtwinlynne is an unknown quantity at this point
Default Mystery clutch / trans problem.
1993 XLH 1200 with only 16,000 miles on the clock.
Riding home from work I was just changing gear and accelerating from about 10mph and.. no drive! This has happened to me once before when the belt snapped but this time the clutch cable had developed excessive slack at the lever and of course I had no tools with me so I couldn't readjust it.
I initially assumed the cable must have broken at the clutch end but when I removed the primary and checked it over it was good. It has a bolt on light clutch device (not the replacement ramp) fitted by the previous owner but that looked good too.
I put everything back together and adjusted the clutch as per the service manual but it won't change gear. The lever clicks through the gears but there's no actual engagement. There was no debris when I drained the oil either and the parts of the shift mechanism I can see still have their springs.
I checked the threads on this forum and I thought it might be the start of the dreaded grenade plate dying so I took it all apart again and fitted an extra plate kit from Energy One. Mind you, the original plates were perfect as was the spring plate. Once back together still no gear engagement. Any ideas? I'm worried that I'm thinking it's a clutch problem when it might be a transmission problem. What would have caused the clutch cable to lose tension like that? I wasn't doing anything outrageous, just negotiating a quiet country road. (Honestly officer...!)
juzyHD's Avatar
juzyHD juzyHD is offline
Bike Builder
Sportster/Buell Year: 1986
Check front pulley, might be loose..?
mikeLI_77's Avatar
Did you check the ramp bearings on the clutch? Could also be the detent plate on the transmission. It is held on my a very flimsy circlip that is known to come off.
2002 XL1200C (originally)
Dyno Sheet
96.21 HP/88.70 TQ
States I Have rode through
vtwinlynne's Avatar
Thanks! I'll check those. The ramp bearings are okay I know but the detent plate I haven't checked or the front pulley.
Old 9th September 2019
Hellbent_4 Hellbent_4 is offline
Sportster/Buell Model: XLH883 Hugger
Hellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud of
If you loosen all the clutch adjustments the clutch should lock up.
At that point put it in gear and try to move the bike.
If it doesn't move then your transmission is probably OK and something is the linkage gave out.
If it does move with no resistance then that would be bad.
If your shifter is clicking then the detent plate is still on and attached to the shift drum.
Old 10th September 2019
Here's the Sportsterpedia section on the Clutch:
http://sportsterpedia.com/doku.php/t...vo:priclutch01
and the Shifter components:
http://sportsterpedia.com/doku.php/t...e_the_trapdoor
vtwinlynne's Avatar
With the clutch adjusted as normal and put into gear I can move it easily as if it was still in neutral but I'll try what you say and report back. No clicking or strange noises either.
vtwinlynne's Avatar
Thanks, I'll do some more reading
