12th September 2019
Posts: 28 Sportster/Buell Model: 883 Sportster/Buell Year: 1994
2001 motor in 1987 frame?
All, apologize for the "ignorance". I've been out of thr game for a bit and have forgotten some small details. I have a spare 2001 motor and I found a 1987 frame. I was wondering if the motor would bolt into that without any issue? Are there any small details between the motors that I cant recall that would keep it from bolting in?
Thanks!
13th September 2019
Posts: 334 Sportster/Buell Model: XLH Sportster/Buell Year: 1995 Sportster/Buell Model #2: Help S3T Sportster/Buell Year #2: 2000
From what I've read on here except for the kickstand mount it will fit. The 5 speed motors stick out more at the back of the primary so the mount has to be cut off and moved / rewelded etc.
23rd September 2019
Posts: 1,406 Sportster/Buell Model: Sportster XLH 883/1207 Sportster/Buell Year: 1986 Sportster/Buell Model #2: XLCH 1000 Sportster/Buell Year #2: 1972
IT will bolt in with little to no issues. frames from 1986-2003 didn't change at all for the engine mounting tabs.
24th September 2019
Posts: 249 Sportster/Buell Model: XLH Sportster/Buell Year: 73
I've accumulated the parts to do the same thing and this article shows how easy it is to move the stand.
https://www.baggersmag.com/sportster...tein-i-presume
I hate any sidestand that's not the classic Harley big twin style so mine will get one of those. The big twin mounting block is easy to copy if I decide to weld one on.
24th September 2019
Momentary Specialist
Posts: 702 Sportster/Buell Model: XL1200 Sportster/Buell Year: 1996 Other Motorcycle Model: ST1100 Other Motorcycle Year: 1999
Thanks for sharing the link.
Sleepy Labeef rides again!
30th September 2019
Posts: 1,555 Sportster/Buell Model: XL Sportster/Buell Year: 1992 Sportster/Buell Model #2: 1978 XLCH project Other Motorcycle Model: Sportster XLH Other Motorcycle Year: 1975
I did know that my flat track Sportster had a 4-speed type frame and a 5-speed engine. I wasn’t aware that was a thing; I had assumed that it had been crashed and rebuilt into any available frame.
I didn’t know about the sidestand mounting, either. I did know that the bike has a short sidestand, from a Hugger or something similar; I carry a piece of 6”x2” timber to serve as a foot for it, to improve the angle and spread the load on soft ground. I’d assumed that this was fitted to keep it tucked away when retracted, but now you mention it, the mounting is definitely further back than stock (of course, both might be true)
