0 Secondery Vin tag
Last Post: supermotolew
2 My 1275 Hammer Conversion..
0 Roadster - No Key Start
Last Post: Skeezix
0 mainshaft rollers size
Last Post: thefrenchowl
0 XLCR replica in progress
0 What engine oil do you use?
Last Post: SLW210
0 81 parts
Last Post: Andy Hog
0 my sunday driver...
0 Halloween 1250 Conversion
0 Top end rattle at 3000 rpm
0 Northern Canada late 1950’s
0 Cam question
Last Post: T. Clark
0 tappet/blocks fitment by year
0 MS rollers way too tight
Last Post: Jaime1840
Last Post: LenC
Last Post: BTD
Old 20th September 2019
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
Default 2003 XLH Battery install help
Well fitting a new battery & hard to get at terminals to put bolts in.
any tricks to make this job easier?
thanks
2003 XL 88"
c1skout's Avatar
c1skout c1skout is offline
Sportster/Buell Model: sportster 1200c
Other Motorcycle Model: Royal Enfield / BMW
c1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant futurec1skout has a brilliant future
When I built. New cables I made my replacements just a little bit longer than factory. That helped.
Stock cables tend to be taunt and can fracture with miles. Heavier gage and extra length,(as mentioned earlier), will help all the way around.
I.B.A.#26543,
ReddTigger's Avatar
I've found that the easiest way was to get the negative started with the battery sideways, then slide it in the carrier and do the positive.
States I've Ridden in
71.3 hp 70.8 tq
Hellbent_4 Hellbent_4 is offline
Sportster/Buell Model: XLH883 Hugger
Hellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud ofHellbent_4 has much to be proud of
I pull my battery every year and it's a pain.
A longer plus cable would help a lot.
Longer ground would help so you could tip the battery a little.
What probably happened was the MoCo thought it would be great to save a couple pennies per bike to shorten the lines an inch.
Old 21st September 2019
Thank you all!!!
I was thinking the cables are short. I'll fit the new battery as is , but I'll look to get longer cables.
Another problem that has shown up ( might be the battery brand? ) but after 13,000k (8,000 mile ) the positive (+) terminal on my SSB brand AGM type battery broke off. I've been riding Harley's since the late 1970's & first time this has happened. anyone else had this happen? I'm in Australia so not sure if you get SSB in USA but it has 450cca so starts my 88" easy ( until the (+) broke off )
BKB's Avatar
BKB BKB is offline
Make your new cables from #2 gauge welder's cable, about 2 cm. longer than the stock cables. Much more flexible, will transmit less vibration & will put less stress on the terminals.
Thanks BKB!! sounds like a positive move!!
Old 22nd September 2019
Yep - It's a pain...
You can check out my battery replacement on My Motorcycle Chronicles -
Click the link in my signature below
Then pick 'Upgrades to KT Since The Build'
Then pick 'Battery - EMP EXT16'
Thank you!!!
