3 Shaky Dave Recovery
0 U.s.m.c
Last Post: 11B40
Last Post: Yakcm2
Last Post: eskimo619
0 Powerraythor conversion
0 question about new trans door
0 Un-Block P-Bucket Pics???
Last Post: Island Dude
0 Multiple timing marks?
0 Side Car.
0 Fuel gauge help
0 Riding in the rain
Last Post: stikflote
0 Handle bar diameter
0 1993 XLH883 Ignition switch Wiring
0 Grrr..Bike just shuts off. No power
Last Post: jcn59
0 Cable lengths
Last Post: jsandidge
0 J and P cycles
Last Post: Skeezix
0 .551 Cams in an EFI 1200
RISport, Sleeper, Chaoszen (66), wojmc (64), Deicer18 (62), PhilR1957 (62), Bikerchk (62), bblbbl (44), 883Hugger (35)
Old 26th September 2019
jkinkade jkinkade is offline
Sportster/Buell Model: XLH 88" 2003.
jkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant futurejkinkade has a brilliant future
I forgot to mention the welder cable works best. I didn't hear about that til after I made mine so mine isn't but it's a good idea. Don't overheat the cable when soldering the copper ends on and don't sweat shrink wrapping the ground all the way to the end. It's just moisture trap and not necessary on the ground.
thank you , I'll remember those tips.
2003 XL 88"
Originally Posted by 84cj View Post
Replaced my battery today as the PO had a loose positive terminal and it melted the post off the battery. I removed the seat for negative terminal access, not much room. AGM went in.
Thank you for that, I will have to look into if mine gets hot.
Good luck with your new AGM.
Old 4th October 2019
Mark Jags's Avatar
Mark Jags Mark Jags is offline
Other Motorcycle Model: Kawasaki Versys
Other Motorcycle Year: 2009
Mark Jags is on a distinguished roadMark Jags is on a distinguished road
I must be really lucky with batteries. The original battery on my 03 lasted over 6 years. In fact the only reason I replaced it is because I was riding out to Sturgis that year and didn't want to take any chances. I replaced it with an H-D battery and believe it or not, that battery just crapped out a few weeks ago. 10 years! And I never, ever disconnect it over the winter or trickle charge it (yeah, I'm lazy....). So I'm probably going to get another H-D battery since I've had such good luck with them in the past.
marksmotogear.com
