0 Blackstone HyperTek
0 Loose oil pump feed fitting - 2019 Iron
0 New users of Windows 10
5 What year is the most collectible Sportster.
Last Post: hhugger
0 Cases Full Of Oil
0 Sprocket cover with chainsikle rearsets?
Last Post: Jason's Sporty
0 On starting a new thread
0 Powerraythor conversion
0 RSD Rear-Sets for '04-'13 Sportsters
Last Post: kobra50
3 Shaky Dave Recovery
0 Deer hunting at stairman's.
Last Post: Bow only
0 Speed
0 gas cap
0 Buy A new battery
Last Post: denguy
14 TC 88A Chat
0 sportster and a grand
gp9739 (75), danbango (72), andyman1958 (61), 55 Jr (58), Love2FixIt (50), keywan (48), C Dubya (45), CA71xlch (44)
Old 23rd September 2019
Ole567 Ole567 is offline
Sportster/Buell Year: 1965
Ole567 is an unknown quantity at this point
Default Dry clutch to wet clutch
What’s the best wet clutch to use in a ‘65 xlch, 66” strocker, sifton cams, etc? The bike is used for hill climbing and the wet clutch in it slips.
Assuming you're still using the '65 clutch basket with stock release parts.
I can't speak from experience but the barnett 303-30-10010 that has stronger springs and extra plate looks like it might work for you.
http://www.barnettclutches.com/1842/...ough-1970.html
The sintered iron plates would be the best but are supposed to be run dry.
On your hill climber couldn't you put the cover on the hub and run a dry clutch? If you couldn't get a perfect seal you could drain the primary oil between events so it wouldn't be sitting in oil when not in use. Just thinking.
Maybe give Barnett a call for advice. Make sure the 303-30-10010 can be run wet or dry. I think it can.
Sportster/Buell Year: 1964
Sportster/Buell Year #2: 1971
http://xlforum.net/forums/showthread.php?t=2001890
Read the clutch info here. I'd prefer to run it dry.
