0 2007 LED Neutral etc display cluster/bar
0 The SPORTSTER car?
Last Post: 1200CustomHD
0 How Indian Makes 43% More Power than Harley-Davidson
0 stumble
Last Post: jbradley46
2 My 1275 Hammer Conversion..
Last Post: XL Dane
0 Do you Run a Fuel Filter?
0 Gear Spacing Question
3 Ironhead Pictures Thread
Last Post: eddie XLX
0 New oil tank
0 Hello from Holland
0 Reflectors...Yeah, or Neh
Last Post: ron521
0 Halloween 1250 Conversion
0 Hi everyone
0 Wanted (Buell Inlet Manifold)
Last Post: gusm2
0 Hello everyone
0 Greetings from Venezuela
0 whats going on?
0 Hello from LA area
0 Starter problem
0 Strengthening 73 rear shock structure
Last Post: Beary
Last Post: 45Brit
0 primary register screw
black pearl (76), SDREDD (59), pig (57), BonRu (55), wandawells42 (51), cbass (47), ssm7530 (45), HawkeyeTX, SxysCowboy (37)
Old 24th September 2019
painterdude923's Avatar
painterdude923 painterdude923 is offline
painterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to beholdpainterdude923 is a splendid one to behold
Default Starter ring gear
I had a few teeth on the ring gear broke off last year so when I had everything apart getting the trans done by R&D motorsports, I replaced the ring gear. What a PITA that was! Started having starter issues again and finally it wouldn't engage at all! Pulled the primary off and holy sh#@ the ring gear is wasted! Anyone know what is wrong? Replaced the original starter with an All balls racing starter. What could I have done wrong with the installation? Been a couple years since I replaced the original. I am cleaning up the mess and not wanting it to happen again! I could use some help please. Thanks
