Last Post: murphdog
0 Cam question
Last Post: T. Clark
Last Post: ericfreeman
0 strange noise in top end
0 Oil leak
Last Post: Roane
0 Old new guy
Last Post: BruceClarke9
Last Post: felis
0 Bike Beast
0 BSA to be reborn...
0 mainshaft rollers size
0 random rattle
0 Loses Power
3 Wtb, Wts, Wtt, Wtg (Evos)
Last Post: iBloke
0 BEWARE Of SCAMMERS!
0 In search of XR1000 parts
Last Post: 84rzv500r
Last Post: LenC
0 84 rear wheel spacer confusion
Last Post: 83XLX
Old 27th September 2019
NLXL's Avatar
NLXL NLXL is offline
Originally Posted by SeaCur View Post
I don't think anyone knows what you're talking about.
I think it's some kind of code like this:
Les longs sanglots des violons d'automne blessent mon cœur d'une langueur monotone.
Je répète:
But that was 75 years ago.
Sportsterpedia
Democracy is the will of the people. Every morning I am surprised to read in the newspaper what I want.
rocketmangb's Avatar
He was looking for me.
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
Old 28th September 2019
SeaCur SeaCur is offline
Sportster/Buell Model: Sportster 1200 XLC
SeaCur is a jewel in the roughSeaCur is a jewel in the roughSeaCur is a jewel in the roughSeaCur is a jewel in the roughSeaCur is a jewel in the roughSeaCur is a jewel in the roughSeaCur is a jewel in the roughSeaCur is a jewel in the roughSeaCur is a jewel in the roughSeaCur is a jewel in the roughSeaCur is a jewel in the rough
Fyi. Make sure both ignition is on and kill switch off, haha. All wiring is done through my stock harness. Pink -> Pink Violet-> Vlt/Blu White -> Wht/Blk. I also added a ground wire from the screw that holds it in place to the black wire, though it was unnecessary. Installed per the manual, then retarded ignition to 28 degrees by rotating roughly .030" CCW
Highly-Dangerous's Avatar
Yes, that always helps too!
[B][COLOR="Red"]CLICK->>[/COLOR][URL="http://sportsterpedia.com/doku.php/start"]"Maintenance is as much art as it is science"[/URL][COLOR="red"]<<-CLICK[/COLOR][/B]
[IMG]http://xlforum.net/forums/attachment.php?attachmentid=20617&d=1576580635[/IMG]
I couldn't find a thread saying anyone used the stock connector or how they did. So often people don't close the loop online, just wanted to give the complete solution to everyone.
Sportster/Buell Model: XLH 883/1250
Sportster/Buell Year: 1991
So, just three wires? Seems easy enough.
John
John
Yep, three and then I added a ground wire for my sanity
Ireeman's Avatar
Ireeman Ireeman is offline
Asgardian
Sportster/Buell Model: 883r
Other Motorcycle Year: abov
Correct, i know of know one else that has played with ignition curves more than you guys.
