0 Tools
Last Post: bklyngeezer
0 Zippers 1250 kit
0 A little MARKET RESEARCH on Skid Plates
Last Post: Marsikus
0 KBS tank sealer
Last Post: wolfryder
0 100 vs 110 front tire
Last Post: dodgetrucken
0 MS rollers way too tight
0 -65A mufflers
Last Post: RussW
Last Post: david.hanaga
0 Brake light issues
Last Post: 45Brit
0 82 XLH struggling for power
Last Post: darkgizzard
Last Post: jon1966uk
0 Newbie
0 50 years of wins, the XR750
0 carbs?
0 Better Brakes
Last Post: mikethebike61
0 my daily driver
Last Post: 84rzv500r
Old 29th September 2019
Sportster/Buell Model: XLH883
Default drive system 'singing'
While riding my '12 1200 Custom yesterday I noticed a whining, or singing noise coming from what I believe is the belt or pulley. It began when were on a downslope with lagging throttle. I pulled in the clutch and the noise continued. It was quite noticeable, so I stopped to check the drive belt (the part that is visible) and found nothing unusual, same with the rear pulley. Is there an explanation for this, or is it a part of the Harley 'mystic'.
Jason's Sporty's Avatar
Jason's Sporty Jason's Sporty is offline
Sportster/Buell Model: Sportster XLH 883/1207
Sportster/Buell Year: 1986
Sportster/Buell Year #2: 1972
Jason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant futureJason's Sporty has a brilliant future
Check belt tension, and rear wheel alignment.
harley506d's Avatar
Sportster/Buell Model: 1200c
Could be an over tight primary chain.
perfectly normal for the belt to make noise and especially so when running out of normal direction of travel. they even make special belts for the noise but i find then not worth while.
