2 My 1275 Hammer Conversion..
0 'Sportster poster
0 Performance gains from TC88A ?
0 Do you Run a Fuel Filter?
0 Starter problem
Last Post: ned-999
0 Tires
0 Reflectors...Yeah, or Neh
Last Post: Marsikus
0 Gear Spacing Question
Last Post: thefrenchowl
0 New oil tank
0 Newbie Question. (Years With Least Electronics?)
Last Post: Eric Von Zipper
0 too much oil in primary
Last Post: 73HEAD
0 New EU rules?
0 Ran out of gas.
5 Which backrest gives more space for passenger?
Last Post: 45Brit
0 Fyi
Last Post: AZbiker
0 Repainted my bike
0 2001 sportster oil line question
Last Post: AudiloveS4
0 Classic Racer game
Last Post: 1200CustomHD
Last Post: Mslisaj
0 How Indian Makes 43% More Power than Harley-Davidson
Last Post: Whitewalls
0 One More Ohio Meet & Eat?
Old 1st October 2019
rebel7's Avatar
rebel7 rebel7 is offline
Sportster/Buell Model: 883N
Sportster/Buell Year #2: 1987
Other Motorcycle Model: VRSCA, FLHRI
rebel7 is an unknown quantity at this point
Default Strange Clutch Problem (2011 883N)
My 883 just hit 20k and something strange happened..
I'm pretty meticulous about clutch adjustments and cable free play, the other day I was taking off from a stop and my clutch started engaging right off the lever, normally it grabs late towards the end travel. Didn't think much, next light, it engages really late like normal. For the entire ride I am playing "guess the clutch" where it wants to engage really early, or really late, but nothing consistent, not a fan. Also noticed it would drag a bit when I would pull it in to come to a stop, like it was still trying to engage.
I haven't changed anything this season aside from the occasional free-play adjustment (which I feel like I am doing way more often now). Yesterday I backed out all the slack, took the cable off and lubed it, got it back to spec, took it for a ride and I noticed the same thing. This cable is at the end of it's days, but this doesn't seem like a cable issue to me, in 2nd it engages where it should, but 1st from a stop is like spin-the-wheel. When it grabs really early, the lever goes limp like it's fully engaged, it doesn't return back to it's normal position.
Worth noting, this thing is my daily, I commute on it (5 miles downtown Chicago) and it deals with a lot of stop-and-go traffic. Could the dreaded grenade clutch spring be wearing? I did the primary oil change and clutch chain adjustment this past winter, thing has ridden really well since the other day.
Do I need a new clutch pack?
Old 2nd October 2019
rejeanprimeau's Avatar
Might be that spring plate, time to get the XR spring ring in.
Plus 1, spring plate most likely the culprit. Drop the fluid out and see if you have shiney brass pieces in it, signifies the rivets failing and most likely scoring your clutch basket. Has happened to many of us.
rebel7's Avatar
Funny you should say that Paul, I just drained it a few minutes ago and saw lots of gold flecks on the magnetic drain plug, also saw some in the oil. Don't like admitting this, but I definitely saw those on the last change and someone had told me it was normal. Went with a new clutch pack on Revzilla and am planning to just change it out. Pretty confident the pack is shot. Going with the BDL plate kit without spring plates.
Tomcatt Tomcatt is offline
Dazed & Confused
Other Motorcycle Year: 2015
Replace the release bearing while you're in there. Put in a 7200B.
Scroll down to: "Clutch Release Bearing Assembly"
http://sportsterpedia.com/doku.php/t...vo:priclutch01
rebel7's Avatar
Just ordered one off Amazon, thanks for the advice Tomcatt!
Not going to be surprised if your clutch basket has damage, if caught early it’s easily repaired. A good bonding moment.
Old 9th October 2019
rebel7's Avatar
So I pulled the clutch tonight, the spacer was shot. Rivets were laying in the basket, but they looked like they came out when I pulled the frictions and steel plates out, so it was on it's way to grenading. Here's my concern, I can see a pretty well defined notch where it looks like one of the friction plates may have ridden hard against the basket, it's so defined that I thought they may come like that from the factory. After looking at pics, I am not so sure. Do these baskets have a notch anywhere? I can take pics.
Grenade plate strikes again...
rocketmangb's Avatar
Thats a spring in the dampener cutting that groove Buddy
Get out the files or dremel
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
rebel7's Avatar
https://imgur.com/gallery/Wlpr0w9
