Last Post: Blowupster
0 starting rollers
Last Post: wongjohnson
Last Post: 45Brit
0 carbs?
Last Post: 83XLX
0 Tools
0 -65A mufflers
0 Name that leak
Last Post: gconnsr
0 KBS tank sealer
0 MS rollers way too tight
0 Stuck #2cam
0 A little MARKET RESEARCH on Skid Plates
Last Post: Marsikus
0 Brake light issues
Last Post: 45Brit
0 Diaphram pressure plate
0 Newbie
Last Post: BitterOldMan
0 50 years of wins, the XR750
Last Post: rocketnorton
0 Zippers 1250 kit
0 100 vs 110 front tire
phantom, JaggedEdge (74), toe (60), john428 (60), testuser (56), rbuier (45), Insane (43), hdtech237 (40), overland47 (39)
Old 9th October 2019
rebel7's Avatar
rebel7 rebel7 is offline
Sportster/Buell Model: 883N
Sportster/Buell Year #2: 1987
Other Motorcycle Model: VRSCA, FLHRI
rebel7 is an unknown quantity at this point
Pics to show. Is that basket shot? How did that happen, none of the teeth on the plates are sheared down.
rocketmangb's Avatar
one of the little bellville springs cut that groove
Ask me how I know
Thy Sportster Come
It Shall Be Done
On Earth as it is on Salt
2006 Sportster XL1250C
Hammer 600 Cams
Big Ass CP/Hammer Pistons
Jetted 27.5 slow,182.5 Main
97 Needle,Clip posistion 3
Patriot Defender Pipe
Napa 7148 oil filter
Max Power, 111.47
Max Torque, 84.39
Best 1/4 Speed to date 115.14
rebel7's Avatar
How do I smooth out a cut that deep though? I don't have a dremel, can I file it down?
Just file out the burrs otherwise you will play hell putting the disc's back in
I filed mine.
Might pull the rotor and look for debris that will short the stator
Again
Ask me how I know
rebel7's Avatar
Okay. When I was taking out the friction plates, one was like hell getting out and looked like it had stuck on it. Had to use a magnet to get them out, though the oil suction makes it difficult. Lots of sludge in there too.
