0 MS rollers way too tight
Last Post: randy3934
0 Newbie
Last Post: wongjohnson
0 OEM Headlight Bucket?
0 Chris Farley Bike
0 Mid Control?!
Last Post: MikeBel
Last Post: leon bee
0 carbs?
0 Happy Thanksgiving
Last Post: bklyngeezer
0 Grateful Dead Timing Cover Source?
0 Halloween 1250 Conversion
0 Better Brakes
0 Northern Canada late 1950’s
0 Oil leaks
0 oil bag
4 1995 S2 buell
Last Post: J!nx
0 Spacer swingarm bearing
Last Post: eddie XLX
0 81 parts
Last Post: Andy Hog
0 SPRINGER Front End JUST RIGHT CHOPPER HEIGHT?
Last Post: Desertfox
0 XLCR replica in progress
Last Post: rg500
Last Post: XL1275
excel50 (79), blazer95 (70), mycle1000, Barryn37 (59), QBALL (59), paulieb (58), cfranz (47), BMXATV (46), ravyn3 (41), Texas_Wild, hillpope (38)
Old 2nd October 2019
LenC's Avatar
LenC LenC is offline
Sportster/Buell Model: NRHS 1250
Other Motorcycle Model: Triumph Bonneville Black
Other Motorcycle Year: '06
LenC has disabled reputation
Default Rear chain adjustment tip
I converted to a 520 chain on my '97.
This tip I discovered is ridiculously small, almost inconsequential and no doubt irrelevant to 99% of you but I'm sharing it anyway.
Suffer.
Trying to adjust the chain and wheel alignment for the past 4 days and every time I got all lined up I'd tighten the axle and the chain would be way too tight and wheel alignment off.
While sitting back to appraise the situation I gazed at the still-stock rear brake and brake holder when I had an epiphany.
"SON OF A %)&@&!!!" I hollered.
A shot of WD40 to the where the brake bracket rubber bumper runs on the swing arm and everything was cured.
Told you it was nothin' but my BP is high enough as it is.
