Last Post: jcro61
0 1968 ex barn dweller thread
Last Post: fernf5
Last Post: ronccc
0 Arlen Ness F-Bomb Pipe Test
0 fork oil change with Ricor intiminators
0 Brake light issues
Last Post: night-train
Last Post: andy2175m4
0 Microsquirt EFI Conversion
Last Post: Randy_rots
0 Sifton cams on stock 74 XLCH
Last Post: lajam175
0 Tools
Last Post: Dariusz
Last Post: Dariusz
0 -65A mufflers
Last Post: DR DICK
0 Chasing a generator noise
Last Post: DR DICK
0 Installing jugs finally but another Q
0 55* this morning
0 2007 883R From Sunny Old England!
0 Pinion shaft holder tool
0 Better Brakes
0 Do you like Mexican food?
0 Covered shocks
Last Post: Heff
0 Xlh 883 oil tank paint
0 starting rollers
0 Potato-potato
6 1983 Ironhead- Final wiring
Last Post: Attaxic
0 is a buell a harley
lineberger, 39dan (62), FstPig (61), jmdajd (57), ironhead 74 (57), erjasn84, Bada Bing (56), ottchuck (55), OutlawTexan67 (53), RAJ (47), Wintersdark (44), robychopper (44), TnsporT (43), MotoSquirrel (36)
Old 13th October 2019
Jer Jer is offline
Sportster/Buell Year: 1991
Jer is an unknown quantity at this point
easy peasy
i have it on my 01 sport
you have to make a pipe to frame bracket. i made mine in two pieces with slotted bolt holes. i then bolted to pipe and frame and adjusted till i got the best fit and then tighten the bolts, removed and welded. the fit will be close to the front wishbone but so far, no issues with mine, the vin decal still in tact.
forgot to add, the bracket will have angles, so to achieve a fit, i tacked the plates so i could tweak the angle on each piece so as to lay flat on each other, did not video. i did not dent the pipe either.
This is what I need! First hand experience!
Any chance you have photos of what you have accomplished? Does your brake pedal clear, or did you have to adjust?
Thanks!
Old 14th October 2019
yes, the pedal rod had to be lengthened but there was enough threading on the rod to accomplish that. that will cause the pedal to swing upward but easy to get used to. perhaps a jpeg between my guitar projects, hadn't started it in a month.
