Last Post: Sasnak75
0 Opinions on Mallory unilite ignition
Last Post: mikethebike61
0 Hydrostatic fuel gauge
0 Chasing a generator noise
Last Post: randy3934
Last Post: oldboy
0 S&s
0 Sifton cams on stock 74 XLCH
0 Installing jugs finally but another Q
0 Li/Ion battery in '03
Last Post: Eric Von Zipper
0 Late-model stator on rigid-mount bike?
Last Post: Curbside
Last Post: 83XLX
0 1968 ex barn dweller thread
0 my sunday driver...
Last Post: 84rzv500r
0 Microsquirt?
Last Post: Curbside
0 Better Brakes
7 Ironhead yes or no
Last Post: exexpat93
Last Post: iBloke
0 fork oil change with Ricor intiminators
wlm (57), Greg81XLH (55), saylor01 (54), Alicia (52), latnyte (51), antonini (43)
Old 11th October 2019
(-_-) (-_-) is offline
Sportster/Buell Year: 2016
(-_-) is an unknown quantity at this point
I actually just changed the oil and oil filter. I left the oil pretty low. Started it and no change. How long should I have to wait for the oil to pump out of the sump? Is there a sump drain plug or only the drain hose? The bike did sit for awhile while waiting on parts and working on other projects.
I tried letting it idle for a bit, I think it might not be scavenging. Still won't rev and the oil tank isn't filling up.
sportsterdoc's Avatar
How much oil was drained when it was changed?
How much oil was then used?
Don't know about 2016, but earlier models had no drain plug, just the hose.
Hippysmack's Avatar
Then I wouldn't fire it back up until you pull the oil pump and inspect the gerotors.
Here is what the parts should look like.
http://sportsterpedia.com/doku.php/techtalk:evoil03g
You can pull the oil pump without removing the cam cover.
You'll need a long 3/16" Allen wrench to get to the back bolt.
There are 2 (front outside, rear inside) bolts to remove the pump and drop it out.
Then 2 more to disassemble the pump.
The are 2 sets of gerotors in the pump, the scavenge gears are in the top portion.
These need to be checked along with the surface in the pump they ride on.
Feel around for metal grit in the oil also.
Do this first and report back.
Hippysmack's Avatar
Actually there is a drain that would pull most of the oil out of the sump but not all of it, especially in the bottom.
This plug is accessible on 03< models but it may be under the frame on 04> models.
We need pics of the oil pump internals.
If the pump is good, you'll need to check the pump drive gear on the pinion shaft.
First things first though.
Maxeffort's Avatar
Momentary Specialist
Sportster/Buell Model: XL1200
If no oil is returning to the tank, something (debris) prob got into the scavenge section of the pump.
Edit.. other posters are on it
Hippysmack's Avatar
I've seen a broken scavenge gear due to the pin getting loose but no damage to the drive gear.
But that may be a special situation.
The gear on the pinion shaft is notorious for wearing and that causes metal shards and ugliness.
It could be something simple like a pinched return line though.
Looked like around 2.5 quarts. Really hard to tell. I uprighted the bike and let it drain out the filter too. Added around 1.75 quarts.
I'm going to pop the oil pump off. Thanks.
Hippysmack's Avatar
Just read the first of this thread, lots of concerns.
The middle 2 cylinder studs may be stripped causing you not to be able to keep torque on the heads.
We just had a member with that problem.
What is the orange junk under the rocker box? It's not RTV is it?
Watched the video. Something is scrubbing but from here, it could be a lot of things.
ANY RTV or other silicone can break loose and stop up oil passages. Not saying it is but just thinking.
