0 Tires
0 Reflectors...Yeah, or Neh
Last Post: Marsikus
0 Gear Spacing Question
Last Post: thefrenchowl
0 New oil tank
0 Newbie Question. (Years With Least Electronics?)
Last Post: Eric Von Zipper
0 'Sportster poster
0 too much oil in primary
Last Post: 73HEAD
0 New EU rules?
0 Ran out of gas.
5 Which backrest gives more space for passenger?
Last Post: 45Brit
2 My 1275 Hammer Conversion..
0 Fyi
Last Post: AZbiker
0 Repainted my bike
0 2001 sportster oil line question
Last Post: AudiloveS4
0 Do you Run a Fuel Filter?
Last Post: AZbiker
0 Classic Racer game
Last Post: 1200CustomHD
Last Post: Mslisaj
0 How Indian Makes 43% More Power than Harley-Davidson
Last Post: Whitewalls
0 One More Ohio Meet & Eat?
0 Performance gains from TC88A ?
0 The SPORTSTER car?
Last Post: lostNdallas
Old 16th May 2006
ed_in_az's Avatar
ed_in_az ed_in_az is offline
ed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond reputeed_in_az has a reputation beyond repute
The 4th gear whine is the only thing that's quieter on my '05 than my '03. It is normal.
2008 Nightster 1200 Convertible: Touring/Bobber SE Stage I
Old 27th May 2006
lollypop lollypop is offline
lollypop has disabled reputation
hi lollypop here in the U/K.i have looked for this site in particular because i did not fit one of my earplugs properly and noticed the forth gear wine more than usual.my bike is a 05 883r and the gearbox has wined from new,i know nothing is wrong due to the design of the gearbox,now i know i iwas right after reading all the comments.my bike runs great and i love it, the wine was the only thing that i had concerns about[mianly on overrun].thanks.lollypop.
Old 27th May 2006
chrishajer's Avatar
Sportster/Buell Year: 1988
For 2005 and earlier 5 speeds:
I wonder if the 4th gear noise is more noticeable because of where 4th gear is in the transmission? The gears are installed like this:
front tire
primary case 4 1 3 2 5 belt sprocket
rear tire
You're moving along at a pretty good clip, so the gears are really slinging around, and the 4th gear is closest to the primary side, and the primary case acts as a big drum, and the normal gear noise resonates. When you drop it into 5th, the 5th gear is locked to the mainshaft and it's direct drive, 1:1, and the noise all goes away.
3rd gear on Big Twins with straight cut gears is similarly loud, because 3rd gear is in the middle of the shaft, where it gets the most deflection, and therefore most noise. 3rd is probably not as noisy on an XL because the shafts are not as long as the Big Twin.
That's my theory and I'm stickin to it.
BTW, in case this makes no sense, the noise in 4th gear is normal. Just ride it.
--Chris
Old 30th May 2006
chrishajer's Avatar
Thought of one more thing. If you're lugging it, i.e. not revving it out enough, it will be noisier than if you keep the RPMs up.
--Chris
Old 31st May 2006
hi ya all,lollypop here in the U/K.been on the look out for this problem as my 883R is doing it[got to admit has done it from new more or less].anyway went to the dealers today[31 5 06]and asked the tech about it,he said forget it!!use it!!after 10grand it will just be the same, ITS NORMAL FOR A SPORTY WITH STRAIT CUT GEARS, thy all do it to a sertain extent.so if gear change is good and the bike is running smooth,ride&enjoy safe.hope this helps.tara for now lollypop in the U/K.
Old 31st May 2006
maddog's Avatar
maddog maddog is offline
Sportster/Buell Model: Hugger 883/1200
maddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura aboutmaddog has a spectacular aura about
AND THE ANSWER IS!
The reason 4th is so loud is that it is the only gear that spins every gear
on both the main shaft and the counter shaft. No other gear spins'em all.
If you look in the field manual under transmission, they show you with color
coding which gears are engaged in each of the five speeds.
Night Train + Street Fighter= NIGHT FIGHTER
MY GALLERY
"It's just a Sportster, but I'm saving up for a Big Twin."
That's like saying...
"It's just a Corvette, but I'm saving up for a Station Wagon."
STEPHANIE FELD
HOT XL MAGAZINE
SUMMER '97
He was asked, "Why do you ride?" He considered the question carefully for a few moments. "The Lean", he replied.
Old 21st August 2006
Little_Dave's Avatar
Little_Dave Little_Dave is offline
Sportster/Buell Model: 2003 heritage model
Other Motorcycle Model: MZ ETZ 250 cc
Other Motorcycle Year: 1986
Little_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura aboutLittle_Dave has a spectacular aura about
Default 4th gear whine
My 2003 883 does it as well, lets me know one more into top!
Old 24th September 2006
shedds's Avatar
shedds shedds is offline
shedds has disabled reputation
DAMN I FOUND OUT 2006 SPORTY,S ARE THE SMOOTHEST AND QUIETEST OF ALL BECAUSE OF HELICAL CUT GEARS (A GUY I TALKED TO RECENTLY SOLD HIS 04 BECAUSE OF GEAR WHINE AND VALVE SEAL ,LEAKY ROCKER BOX AND BOUGHT A 2006 NOW HE IS ONE HAPPY HARLEY OWNER) i hate that guy !!!!!
Old 10th October 2006
doxbike doxbike is offline
Sportster/Buell Model: FatBob
Sportster/Buell Model #2: all gone 1200R
Other Motorcycle Model: Honda ST1300;Goldwing1500
Other Motorcycle Year: 0407
doxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of lightdoxbike is a glorious beacon of light
Question Transmission whine
My '07 1200R has a high pitched "yowl" as opposed to a "whine" that's especially noticeable if you're riding next to a wall. I can't hear it on the open road, but it is present if I'm next to a flat walled cage. Normal or not normal? Sorry Howie.
maddog's Avatar
Normal...Walls, tunnels, ETC. all exaggerate sounds. Don't pay any attention.
